The big switch
Old Feb 19, 2006 | 07:36 PM
Funny Man's Avatar
Funny Man
Default The big switch
Guys, I think it's about that time for me to get a REAL Man's truck, yes I'm talking about a Diesel 4x4. If there is any reason why I shouldn't that I don't know about, please let me know. I was thinking about getting a 2500 4x4 98-02, a Ram of course!
Thanks
Old Feb 19, 2006 | 09:49 PM
MGDMike's Avatar
MGDMike
Default RE: The big switch
Uhm...deisel gas is pretty high. But, it seems to be pretty good with mileage. What kind of loads are you plan on hauling.
Old Feb 20, 2006 | 02:44 AM
hawkeyedodge's Avatar
hawkeyedodge
If you live in the midwest, and have availability to 'SOY BIO-DIESEL' then go for it, its about 1.00$ a gallon cheaper than regular diesel and is more efficient as well as clean. I live in Iowa and bio diesel is the ****, I just wish it would've been available before I bought my truck, otherwise I would've bought a 3/4 ton diesel instead of a 1/2 ton gasoline.
Old Feb 20, 2006 | 07:38 AM
Funny Man's Avatar
Funny Man
I really have no need to pull or haul anything, I just want a diesel 4x4, my buddy and I are both looking for a diesel truck so we can make our own bio-fuel!!! And go mudding of course!!!!!!
Old Feb 20, 2006 | 07:49 AM
young buck's Avatar
young buck
hey man deisels rock the only thing that kept me from getting one is i dont really know anything about working on the deisel engine but a couple of my buddys have them and have them jacked up and man they put out serious ponies i like them man go for it if u got the money
Old Feb 20, 2006 | 04:59 PM
20dodgeram01's Avatar
20dodgeram01
those things can pull a house down if you wanted. should see them at the diesel truck pulls 4x4 diesel 6speed on 37's with 600+ torque. switched into 3rd pulling that sled and steady hopped and spun all 4 tires. takes some SERIOUS power to do that!
Old Feb 20, 2006 | 05:24 PM
Silver_Dodge's Avatar
Silver_Dodge
For 4x4'ing and mudding, I would not recommend the diesels. Yes, the have boat loads of torque, but that front end is extremely heavy. I have seen gas trucks go through mud holes no problem, and the diesel just sink down in the front, getting stuck past the axle. Also, off-roading with a diesel can be tough, again due to the weight. The ideal setup is something that has good torque, but is relativiely light weight.
If you want a towing machine, then no question - get the Cummins!
Lastly, maintenance can be a little more expensive to. Take changing oil for example. I can't remember the exact amount, but there is about double the amount of oil of what comes in V8.
Old Feb 20, 2006 | 05:26 PM
steve05ram360's Avatar
steve05ram360
I've been considering the exact same thing... wanting a cummins diesel 01 or newer, I think however maint costs are a bit higher. Not sure about the costs of repairing but it's like anything else... learn as you go and you'll find cheeper ways to fix things..
I think there is plenty of upgrades out there too... My brother has a Power stroke ford that he did the hypertech program to and he couldnt believe the HP it added.
Old Feb 20, 2006 | 06:27 PM
Silver_Dodge
Something else I thought of that you might want to consider before taking the plunge with a diesel. You didn't say were you live, but diesels require extra attention in the cold winter climates. They start very hard, and you will need a block heater and ability to plug it in at night. Also, diesel fuel can gel up in extreme cold temps. We had this happen on my brother-in-laws '99 this weekend. Granted, it was -10 which is somewhat rare for eastern Colorado, but it really sucked none the less.
I'm not trying to talk you out of it, just some stuff I thought of.
One of the best reasons to get a diesel is longevity. If properly maintained, a diesel engine can easily run 200,000 + miles. Not that gas enignes can't also do the same, but it is just more common in a diesel. If I ever upgrade from my gasser to a diesel, it will be because of towing/hauling ability, and longevity.
