Swapped the Fuel Pump...
Old Feb 28, 2006 | 06:04 PM
Socha_62's Avatar
Socha_62
Default RE: Swapped the Fuel Pump...
Light pinging is normal huh...I don't care how small itis. My engine does it I'm gonna find out wahts wrong with it.
Old Feb 28, 2006 | 07:10 PM
steve05ram360's Avatar
steve05ram360
on older motors, when you heard it pinging, you'd back the timing off just a hair till it's gone. Pinging = loss in power in my book. I dont believe it is normal for a motor to ping under any load.
my problem is not light pinging... it's pretty sevear... enough for me to back out of the throttle all the way when it happens...
Old Feb 28, 2006 | 07:27 PM
Fubba's Avatar
Fubba
What octane fuel are you running Steve?
Old Feb 28, 2006 | 07:52 PM
steve05ram360
I thought there was only 1 octane out there... 91...? huh? jk I wish i could get 93 though...
the best I can get is the 100 stuff across the freeway. but at 5.25/gallon... makes fillups kinda expnesive. there are a couple of stations that are cheeper, just not close.
Old Feb 28, 2006 | 11:55 PM
ryans590's Avatar
ryans590
while you pepole are on the subject of pinning what exactley duz it sould like and wen should i listen for it? i kinda have an idea what it is but i dont think ive ever herd it even wen ive got my foot to the floor going up a hill and with all this talk about everyone having it is making me wonder
Old Mar 1, 2006 | 12:48 AM
steve05ram360
sounds like a rattle coming from the motor....
Old Mar 1, 2006 | 12:59 AM
ryans590's Avatar
ryans590
rattle like shaking a babbys rattle? how loud is it? is it easy to hear over the moter in the cab?
Old Mar 1, 2006 | 01:11 AM
Fubba's Avatar
Fubba
What's your CR Steve? I'm running 10:1 in my old car and have to run 93.
ryans590, You won't be able to hear really really light pinging when in the cab, but you should be able to hear most pinging. It's a sound that shouldn't be there and you'd notice it if you heard it.
Old Mar 1, 2006 | 01:17 AM
steve05ram360
dont know what the CR is now... it's a stock block with the R/T heads. I think the CC is smaller on the R/T's so the CR would go up some but i'm not sure how much.
Old Mar 1, 2006 | 01:48 AM
Fubba's Avatar
Fubba
The smaller combustion chamber will boost the CR. I think stock is around 8.4:1, so you should be in the ballpark of 9:1 or a little higher. You SHOULD be able to run 91 with no problems. Has the distributor been messed with at all?
