steve05ram360
close
- Join DateJan 2004
Liked:308 Times in 287 Posts
nope, just has about 170k on it.
How is your EGR valve? Has it ever been replaced? I assume you're not running hot, so that can't be the problem. You may want to try putting a couple of gallons of the 100 octane in next time you fill up and see what that does.
steve05ram360
close
- Join DateJan 2004
I dont have an egr valve. I think it is plug related. with the MSD setup, I was running NGK's a while back and they were worn to the point that they would cause pinging under heavy load. Swapped in some Bosch 2's to see how it would run with them in there and it's been ok for the most part. The pinging i've heard has only happened witht eh Bosch 2's in there. That could be the problem. The goal was to find a plug that would last 20~30k miles or more before needing replacing...
hi,
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 09-06-99, DATED SEP. 10, 1999, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A COMPLETE REVISION AND NO ASTERISKS HAVE BEEN USED TO HIGHLIGHT REVISIONS.
Models: 1994-1999 BR/BE Ram truck V6, V8
1994 -1999 (AB) Ram Van
1994 -1999 (AN) Dakota
1994 -1999 (BR/BE) Ram Truck
1998 - 1999 (DN) Durango
1994 - 1998 (ZJ) Grand Cherokee
1996 - 1998 (ZG) Grand Cherokee
THIS APPLIES ONLY A VEHICLE EQUIPPED WITH 3.9L, 5.2L or 5.9L GAS ENGINE.
Discussion:
This bulletin involves the replacement of the engine intake manifold plenum pan gasket.
Symptom/Condition:
An engine intake manifold plenum pan gasket oil leak may occur on some V-6 and V-8 style engines. The oil leak is internal to the engine so no external oil leakage will be present. Two symptoms of this oil leak condition may be present. The vehicle operator may experience an engine spark knock during acceleration and/or an increase in the amount of engine oil consumed by the engine.
Diagnosis:
Make sure Technical Service Bulletin (TSB) 18-48-98 has been performed.
NOTE: IT IS IMPORTANT THAT THE COIL AND SPARK PLUG WIRES ARE ROUTED EXACTLY AS SPECIFIED IN TSB 18-48-98 TO ACHIEVE THE MOST BENEFIT.
Inspect the Positive Crankcase Ventilation (PCV) valve. Shake the PCV valve to verify that the pintle inside of the PCV valve is free. Replace the PVC if the pintle is not free.
If the intake manifold plenum pan gasket is leaking, an additional vacuum source will be created inside of the engine at the location of the pan gasket leakage.- Engine combustion blow-by gases, oil vapor, and air from the crankcase filter/breather may be drawn past the leaking pan gasket and into the intake manifold. In most cases when this condition occurs, an engine at idle will create the highest vacuum and lowest amount of engine blow-by.
1. Allow the engine to reach normal operating temperature.
2. Stop the engine.
3. Disconnect the breather hose from the air cleaner.
4. Attach a vacuum I pressure gauge to the end of the breather hose (Figure 1).
1 - VACUUM / PRESSURE GAUGE
2 - BREATHER HOSE
3 - VALVE COVER BREATHER HOSE PORT
5. Disconnect the PCV valve hose from the intake manifold.
6. Seal off the intake manifold PCV valve hose port opening.
7. Seal off the open end of the PCV valve hose (Figure 2).
NOTE: DURING THIS DIAGNOSIS, IT WOULD BE NORMAL FOR THE ENGINE TO DEVELOP PRESSURE WITHIN THE ENGINE CRANKCASE. THIS IS DUE TO -THE NORMAL PROCESS OF. EXHAUST BLOW-BY- GASES- LEAKING PAST THE ENGINE PISTON RINGS AND ACCUMULATING IN THE ENGINE CRANKCASE. DO NOT ALLOW MORE THAN 3 PSI (20.7 kPa) OF PRESSURE TO BUILD WITHIN THE ENGINE WHEN PERFORMING THE FOLLOWING DIAGNOSTIC PROCEDURE.
8. Start the warmed engine and observe the vacuum gauge.
9. Allow the engine to idle for approximately 30 seconds. Do not allow more than 3psi (20.7 kPa) of pressure to develop in the engine crankcase.
10. If the attached vacuum I pressure gauge does not indicate that a vacuum is present in the engine crankcase, then the intake manifold plenum pan gasket is good and no further internal engine vacuum leak diagnosis is required.
11. If an internal vacuum leak is present then perform the Repair Procedure.
Parts Required*:
For the 5.2L / 5.9L:
1 04897383AC Package, Intake Manifold Flange Gasket and Bolts
1 05017208AA Gasket, Intake Manifold Plenum Pan
15 06034583 Bolt, Intake Manifold Plenum Pan
1 53030541 Gasket, Throttle Body'
2(AR) 04318001 Conditioner, Combustion Chamber
For the 3.9L:
1 04897382AC Package, Intake Manifold Flange Gasket and Bolts
1 05017207AA Gasket, Intake Manifold Plenum Pan
14 06034583 Bolt, Intake Manifold Plenum Pan
*NOTE: the part numbers are continually being revised. Use the most recent part numbers from the dealership computer if you perform this repair yourself.
Repair Procedure:
1. Refer to the appropriate year Service Manual, Section 9: ENGINE for removal and installation instructions.
NOTE: CLEAN ALL OIL RESIDUE FROM THE INTERIOR SURFACES OF THE PLENUM PAN AND THE INTAKE MANIFOLD PLENUM CHAMBER.
NOTE: THE PROPER BOLT TORQUE AND TIGHTENING SEQUENCE IS CRITICAL AND MUST BE FOLLOWED WHEN TIGHTENING BOTH THE PLENUM PAN BOLTS AND THE INTAKE MANIFOLD FLANGE BOLTS.
3.9L Bolt Tightening Sequence and Torque Procedure:
3.9L Plenum Pan Bolt Torque Procedure
STEP WHICH BOLT TORQUE
1 All Bolts 5.4 Nm (48 in. lbs.)
2 All Bolts 9.5 Nm (84 in. lbs.)
3 Check All Bolts 9.5 NM (84 in. lbs.)
3.9L Intake Manifold Flange Bolt Torque Procedure
1 1 and 2 1.4 NM (12 in. lbs.)
2 1 and 2 2.7 NM (24 in. lbs.)
3 1 and 2 4.1 NM (36 in. lbs.)
4 1 and 2 5.4 NM (48 in. lbs.)
5 1 and 2 6.7 NM (60 in. lbs.)
6 1 and 2 8.1 NM (72 in. lbs.)
7 3 through 12 8.1 NM (72 in. lbs.)
8 Check All Bolts 8.1 NM (72 in. lbs.)
9 All Bolts 16.3 NM (12 ft. lbs.)
10 Check All Bolts 16.3 NM (12 ft. lbs.)
5.2L/5.9L Bolt Tightening Sequence and Torque Procedure:
5.2L / 5.9L Plenum Pan Bolt Torque Procedure
1 All Bolts 5.4 NM (48 in. lbs.)
2 All Bolts 9.5 NM (84 in. lbs.)
5.2L / 5.9L Intake Manifold Flange Bolt Torque Procedure
1 1 and 4* 1.4 NM (12 in. lbs.)
2 1 and 4* 2.7 NM (24 in. lbs.)
3 1 and 4* 4.1 NM (36 in. lbs.)
4 1 and 4* 5.4 NM (48 in. lbs.)
5 1 and 4* 6.7 NM (60 in. lbs.)
6 1 and 4* 8.1 NM (72 in. lbs.)
7 5 through 12 8.1 NM (72 in. lbs.)
* The bulletin clearly says to tighten bolts 1 and 4, but this is probably a typo because the service manual says to tighten bolts 1 through 4, and nowhere in the TSB does it say to tighten bolts 2 and 3, which would only be tightened to 12 ft. lbs when you reach step 9.
2. With the engine reassembled, inspect the coil and spark plug wires for proper routing. Refer to TSB 09-48-98 for additional assistance.
3. Start the engine and allow it to warm to normal engine operating temperature.
4. Decarbon the combustion chamber using Mopar Combustion Chamber Conditioner (p/n 04318001) per the instructions.
NOTE: ALLOW THE COMBUSTION CHAMBER CLEANER TO SOAK INSIDE OF THE ENGINE FOR 2 TO 2.5 HOURS. NOTE: A SECOND APPLICATION OF THE COMBUSTION CHAMBER CONDITIONER MAY BE REQUIRED IF THERE WAS A LARGE QUANTITY OF OIL LEAKAGE PAST THE INTAKE PLENUM PAN GASKET.
5. Verify proper engine oil level.
Notes:
Policy: Reimbursable within the provisions of the warranty.
Time Allowance:
Labor Operation No: 09-50-15-91 .................................. 3.0 Hrs.
Optional Equipment:
09-50-15-60 Air Conditioning Equipped (AN/BR-BE/DN/ZJ) ............ 0.2 Hrs.
09-50-15-60 Air Conditioning Equipped (AB) .................................... 0.8 Hrs.
09-50-15-62 Air Injection Pump Equipped (SR/BE) ........................... 0.2 Hrs.
09-50-15-65 Power Steering Pump Equipped (if 5.2L and AN/BR-BE/DN/ZJ) .. 0.2 Hrs.
Failure Code: P8 - New Part
Greasemonkey.
Discussion:
Symptom/Condition:
Diagnosis:
2. Stop the engine.
2 - BREATHER HOSE
Parts Required*:
For the 3.9L:
Repair Procedure:
Notes:
Time Allowance:
Optional Equipment:
Greasemonkey.
I've never liked Bosch's that much. NGK makes a good plug. It's what I have right now. Accel makes good ones as well. I guess it's something you could try.
steve05ram360
close
- Join DateJan 2004
the ngk's that I pulled out were pretty shot. I had about 20k on them too. (MSD ignition). I think i'm gonna go with an autolite 3923 to swap them out with and see if the pinging goes bye-bye... I think it will.
steve05ram360
close
- Join DateJan 2004
no more v-grove on 1/2 of them... shot...
Ahh okay...gotcha. Some people mean they're black when they're shot...shouldn't have put that one by you Steve. I know better
You can try the plugs and see what happens. It's an easy change. If that doesn't work, then I'd mix around 3 to 5 gallons of the 100 octane and see what happens.
You can try the plugs and see what happens. It's an easy change. If that doesn't work, then I'd mix around 3 to 5 gallons of the 100 octane and see what happens.steve05ram360
close
- Join DateJan 2004
funny thing about this ping... it is the nastiest ive ever heard out of my ram. only heard it 2 other times and both were on these plugs.
