1998 inside cab water leak
Old Feb 26, 2006 | 09:35 PM
petekf4qoe's Avatar
petekf4qoe
Default 1998 inside cab water leak
I am at my witts end. I have a water leak in my 1998 Dodge Ram 1500 quad cab. This is a 2 wheel drive truck and I have had a water leak on the passenger side around the floor near the door and kick panel. I took the kick panel and door sill plate off and noticed the water seems to be coming in around the area behind the kick panel. But I can not find out where the water is coming from. PLEASE HELP. I am tired of this and want to stop it now. Any ideas would be appreciated.
Old Feb 26, 2006 | 09:39 PM
ryans590's Avatar
ryans590
Default RE: 1998 inside cab water leak
sounds to me like you have leak in your heater core. duz it smell like antyfreeze in there (kind of a sweet smell) even if not that would be my first place to look but if it duz its a giveaway
Old Feb 26, 2006 | 09:48 PM
petekf4qoe's Avatar
petekf4qoe
No it is not a heater core leak. I have already had that replaced, but not for that reason. It is a rain water leak. Thnaks for the info though. I had found that this is a somewhat common problem but what I had found out about the fix didnt help me.
Old Feb 26, 2006 | 10:10 PM
ryans590's Avatar
ryans590
hmm i havent herd of this prob b4 i have a 98 aswell id say its maby a door seal possabley or a bad winshield seal
Old Feb 26, 2006 | 10:56 PM
The Burning Rom's Avatar
The Burning Rom
You can test for leaks by having someone spray the truck with water in that area of the cab while you sit inside and look for a leak. Or better yet, run it through the car wash. Have someone else drive while you look for it.
It definitely sounds like a door seal or a windshield seal. Either that or the drain for your heater core is plugged.
Old Feb 27, 2006 | 12:36 AM
Socha_62's Avatar
Socha_62
Somebody else was having this problem, as far as I remember they never really found it. Or they didn;t tell us if they did.
Old Feb 27, 2006 | 12:55 AM
petekf4qoe's Avatar
petekf4qoe
read below. This is the problem that I am having. It is a TSB from Dodge. I checked my truck and it has already had this done to it.
http://dodgeram.info/tsb/1997/23-68-97.htm
Old May 31, 2006 | 08:43 PM
BEELZEBOB's Avatar
BEELZEBOB
If you haven't found anything, see my reply to bluefin's 5/22 post - might be worth a shot - bbb
Old May 31, 2006 | 08:55 PM
xtech's Avatar
xtech
I had the same problem on a 2000 BE (Quad Cab). It was the third brake light lamp. Water was coming in around it, down the head liner and to the floor. Reseal the stop lamp and the water stopped.
