Air Hat?
Old 03-30-2006, 01:52 PM
ryans590's Avatar
ryans590
ryans590 is offline
Default RE: Air Hat?
ORIGINAL: JustinJohnson86
Ether = Starting Fluid...
i know what it is just making its safe to use on a gasser
Old 03-30-2006, 02:31 PM
JustinJohnson86's Avatar
JustinJohnson86
JustinJohnson86 is offline
lol my bad, wasnt quite awake this morning... Coffee and cigerrette to get started ya know?
Old 03-30-2006, 03:03 PM
MiaTurbo's Avatar
MiaTurbo
MiaTurbo is offline
the bracket is probably holding it up a little. I'd slot out the hole in the bracket a little so you can adjust it..
Old 03-30-2006, 03:04 PM
dflyboy's Avatar
dflyboy
dflyboy is offline
If you get too much either in there it will actually make it bog down. Propane is better if you can use it. and it wont damage any electical parts like either might.
Old 03-30-2006, 03:09 PM
MiaTurbo's Avatar
MiaTurbo
MiaTurbo is offline
a quick squirt of aerosol starter fluid isn't going to do any damage. Now sitting there and emptying the can probably isn't a good aidea
Old 03-30-2006, 03:11 PM
JustinJohnson86
Another idea is just get some throttle body cleaner.. if the engine bogs ... yeah then theres a leak...
It also cleans it a little
Old 03-30-2006, 03:40 PM
Chopper1's Avatar
Chopper1
Chopper1 is offline
If you can see an air gap, it's leaking. Hit some wet mud and you'll know for sure.
