Air Hat?
Air Hat?
ok i was out poing around on the weekend on my truck and noticed there is still a small gap between the air hat and the TB i tryed using some of that cork stuff to make your own gasket out of, the 1/8 stuff i thought isince it was thicker it could sit down into it but its still lose so i have 2 questions 1 im pritty shure its sucking air there but can i spray eather ther and listen for an rpm jump and 2 anyone got any ideas on how i can get my air hat sitting better here is a cupple pics
[IMG]local://upfiles/27664/03F19913D8BE410D871CCF827E7423A4.jpg[/IMG]
[IMG]local://upfiles/27664/08C5C66DE57D4239A4E677A7D6D85675.jpg[/IMG]
RE: Air Hat?
ORIGINAL: habeba86
I would guess its like that jst bcuz is a ractive air intake. Look at all that wiring[sm=insomnia.gif]
the reson i got the ractive is because the K&N wont work in my tryck becaue i have an aux bat and thar wirring there that i dont wanna move...i do have a cover for that wirring but it was off at the time of the pic and i plan to re-loom the rest this summer
the wirring if for a bunch of things, 3 sets of driving lights, 1 set of backup lights, quad beam head lights, power for my aux cig lighter outlets, and there is silonoids for my dual bats, and traler wirring, thats all i can think of
Trending Topics
RE: Air Hat?
Since your filter is directly above the exaust manifolds, you should build a heat shield at least (that's one of the benefits of a K&N or RamAirBox setups) so it is not sucking in that hot air (and that air is not just warm, it is hot). Here are some pics of the shield I made back when I had an Airaid CAI. The back of the shield (side facing the exhaust manifold) is covered in ThermoTec heat barrier. It worked really good. There was a very noticable temp difference around the filter.
[IMG]local://upfiles/9095/9CCC179007F74CDABBFFCD30971E31BC.jpg[/IMG]
[IMG]local://upfiles/9095/A47D642F82F54EC7AD40084C26C3DC2A.jpg[/IMG]
RE: Air Hat?
yah the plan is to build some box around it thats why i got it insted of a k&n dropin there isent any i could find that were a true CAI that would work in my truck with the setup i have and i dont wanna half to move what i have so i thought this would be the next best thing....im starting to wonder im thinking of some thick but semi soft high dencity foam i dont wanna silocone it on or anything like that i want it sitting good so if i half to take it off i dont halfo to worry about geting off all that silisone. the outher thing i wanna make shure is checking it i wanna make shure my thoughts on it leaking are correct i know on diesles you can use eatner by spraying it around the suspect area and listen for a rpm jump if so thats the leak...well can you do it on a gasser without hirting anyting
