Bad tread ware problem
Old Apr 4, 2006 | 12:30 PM
  #21
HuntinHanson's Avatar
HuntinHanson
Default RE: Bad tread ware problem
for those of you who have replaced the trac bar. I havent had a chance to get under and check it out yet. Is it pretty easy to do? Does it just bolt right up? Any special tools needed?
Old Apr 4, 2006 | 01:00 PM
  #22
Chopper1's Avatar
Chopper1
Here's one for the DT tracbar. Same to remove. Then reinstall. http://www.pavementsucks.com/tech/dtbar.php
Here is a thread on it. https://dodgeforum.com/m_94960/tm.htm
Old Apr 4, 2006 | 01:04 PM
  #23
eslock's Avatar
eslock
when yall rotate your tires you always just do them front to back or do you ever do side to side. my right front gets wear on the outside but i was told it wasnt my alignment but the way the roads are made so they drain.
Old Apr 4, 2006 | 01:48 PM
  #24
Chopper1's Avatar
Chopper1
I go front to back. The back wears flatter(not turning), and the wear evens out with front from switching. If you only have one front wearing then either there is something worn/out of alignment, you are making harder left turns and digging it in, or the air is low. IMO
Old Apr 4, 2006 | 02:10 PM
  #25
HuntinHanson
i rotate mine criss cross (front driver to rear passenger, front passenger to rear driver) if you decide to do that you have to make sure you dont have directional tread though.
