FASTER !!!!!!!!!!!!!!!!!
Old Apr 17, 2006 | 08:40 PM
Zacman's Avatar
Zacman
Default FASTER !!!!!!!!!!!!!!!!!
Alrighty everyody I need your help I have a 2001 dodge ram 1500 v8 5.2 liter I have done everything with the inside and the outside now I need to make it quicker what do I need to know I have already installed a K&N air filter but I need the extra push and speed. So I thought I would ask the experts what should I do? Please help.
Thanks ZAc
Old Apr 17, 2006 | 08:46 PM
HuntinHanson's Avatar
HuntinHanson
Default RE: FASTER !!!!!!!!!!!!!!!!!
Hypertech PPIII, Fastman Throttle Body, CAI, Dual Exhaust
DevilsReject's Avatar
DevilsReject
Noob Assassin
ORIGINAL: Zacman
Thanks ZAc
All depends on your budget really. New headers, custom exhaust, and a programmer are probably the top 3 I would suggest. The programmers are on sale thru TruckAddon's for $275....which is $125 less then normal. You could also invest in a better/bigger throttle body.
Old Apr 17, 2006 | 09:38 PM
JustinJohnson86's Avatar
JustinJohnson86
if you got 5 grand to spend make that 318 a 390 stroker =D Might suffer some downtime of the truck but if you can get yourself a Magnum block (doesnt have to be magnum, but the LA blocks require more work) and a stroker kit along with a camshaft with a longer duration and slighty more lift, and r/t heads and a M1, you could be set =) This is all with doing work yourself.
Or you can just put a 50-70 HP shot of nitrous, I think the pistons/crank can hold that kinda power, i wouldnt go with anymore tho. Also dual exhaust as others mentioned, along with the TB, and roller rockers (1.7 crower are nice from what i heard)
Old Apr 18, 2006 | 12:30 AM
shott8283's Avatar
shott8283
nos would be cool if your lookin for something quick and not consistant... im not sure but i think RM_Indy is squezing his motor... or was atleast
headers TB CAI hypertech duals aftermarket heads.. 1.7 RR's port polish ... elec fans ..blower/charger/turbo (leaf blower motor jammed into the intake works the best ) the list goes on... just depends how deap your pockets are and how much time you want to invest in the truck!
Old Apr 18, 2006 | 03:12 AM
20dodgeram01's Avatar
20dodgeram01
i have a low temp stat, replacent k&n filter, hypertech programmer and a single out flowmaster on my 2001 1500 5.2.. stock gears though with 285's.. i can steady pull from a 1999 4x4 offroad 1500 with the 318 and i believe they have 4.10 gears.. next up will be cai, 50mm throttle body and when i get about 1000 bucks.. new exhaust from the motor back
Old Apr 18, 2006 | 03:13 AM
20dodgeram01
and stock we were DEAD even.. our mirrors were side by side all the way up to 75 then hit the next redlight.. also i have a 5 speed manual and he had a automatic.. not sure who has the better deal there
Old Apr 18, 2006 | 03:59 AM
Racinfan83's Avatar
Racinfan83
Check the list of mods in my signature......I am happy with the performance of mine now. It won't light the tires - but it is a WHOLE LOT snappier. My last mod was the 180 thermostat - and that seemed to be the kicker that helped my other mods work. My mileage has increased from 11.8 to 12.8, and I got 13.6 on a highway trip today. Fastman TB - $225, Hypertech - $284, MSD wires - $90 (splurge), T-stat - $7, K&N - $50, Flowmaster cat back duals - $299 at Midas.......
