Old Aug 5, 2015, 07:46 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior
Print Wikipost
removing fender
Old Apr 29, 2006 | 04:36 PM
discofreak's Avatar
discofreak
Default removing fender
well, as the title states, i need to remove the passenger side fender. i undid all the bolts i could see that attached it to the rest of the truck, but i couldn't get it off for the life of me. is this harder than i think it is? or is there some trick to it?
btw, i have a '99 1500 QC, Laramie SLT.
thanks in advance.
Old Apr 29, 2006 | 06:19 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: removing fender
Straight from the service manual.........
(9) Remove bolts attaching front fender to cowl reinforcement
(10) Remove bolts attaching front fender to radiator closure panel.
(11) Remove bolts attaching bottom of front fender to rocker panel lower flange
(12) Open right door.
13) Remove bolt attaching front fender to hinge pillar mounting bracket
14) Remove bolts attaching top of fender to radiator closure panel
15) Separate right front fender from vehicle.
It also says to remove the front bumper, but I'm not sure if that's necessary. Check out this thread for your own copy of the manual: https://dodgeforum.com/m_340929/tm.htm
Old May 3, 2006 | 12:09 AM
discofreak's Avatar
discofreak
thanks a bunch, that really helped. i wish i had known about this manual a LONG time ago. i've been figruing stuff out for myself for ages, and it JUST NOW occured to me to do a search for a forum that might help!
Old May 3, 2006 | 12:44 AM
shott8283's Avatar
shott8283
I think we need to rename the sticky for the manaul from Merry Christmas, to DOWNLOAD THIS!
Usefull tool, especially when you have a computer in the garage you can load it on and just go back and forth to it instead of trying to print out all 5000000 pages of it.
Old Nov 12, 2008 | 11:25 PM
Keegan's Avatar
Keegan
So... does the bumper have to come off???
Old Nov 13, 2008 | 03:28 PM
PurplDodge's Avatar
PurplDodge
No it doesnt. I took the right off last weekend to make the Crank Sensor Mod kinda eaiser. You also have to remove th top black bumper pad, antenna, and headlight.
Old Nov 13, 2008 | 10:40 PM
Keegan's Avatar
Keegan
Yup I have all the bolts and headlight etc removed, just ran out of time to fully remove the fender, and I wanted to wait to hear about the bumper... thats excellent, thanks!
Old Nov 13, 2008 | 11:24 PM
PurplDodge's Avatar
PurplDodge
since you are taking the fenders off, now is a good time to clean the motor and do the crank sensor mod
Edit: also, put tape in the door jam to prevent scratching
Old Jun 22, 2017 | 09:46 PM
Casey Hughes's Avatar
Casey Hughes
What is the crank sensor mod?
Old Jun 22, 2017 | 10:14 PM
Purpl hasn't been around for a while. He sold his truck. But, I think he slotted the mounting tabs, to give a few degrees of adjustability on the crank sensor.
