Whom ever built thier own lockers, Need help!!
Old May 17, 2006 | 02:23 PM
dodge_boy31807's Avatar
dodge_boy31807
Default Whom ever built thier own lockers, Need help!!
I wasn't wanting to ask who ever built their own locker, how they did it and what they used.
Old May 17, 2006 | 03:37 PM
GOD RAM IT's Avatar
GOD RAM IT
Default RE: Whom ever built thier own lockers, Need help!!
how about being a little more specific.
what axle are we talking about?
are you talking about welding the spider gears?
doing a spool?
installing a locker?
rebuilding a locker?
Old May 17, 2006 | 03:56 PM
dodge_boy31807
I'm talking in the rear end. Some on where had a post about they built their own locker out of a few materials and it didn't cost that much. I'm not really doing this for my truck but need the information on how to do it for a buddy. He doesn't want to buy a locker for the truck and doesn't want to weld the spider gears up either. Quick question though, is it hard to weld a spider gear?
Old May 17, 2006 | 04:53 PM
GOD RAM IT's Avatar
GOD RAM IT
if you're a good welder than its easy.
I highley doubt that someone built their own locker. I know people have built their own posi-lok, which is a center axles disconnect that replaces the stock CAD unit. It makes it mechanical instead of air. It also alows you to have 2 low.
Old May 18, 2006 | 11:28 AM
dodge_boy31807
Well I read on here where someone made something out of brake cable from a bicycle or something.
Old May 18, 2006 | 11:44 AM
GOD RAM IT's Avatar
GOD RAM IT
yup thats what I described. All it does is connect the intermediate shaft to the axle shaft basically eliminating the stock CAD system (which is done by vacuum).
Old May 18, 2006 | 02:29 PM
dodge_boy31807
Well what actually does that do, I really don't understand the consept of it. If you could explain how to do it and Ill try it out.
Old May 18, 2006 | 03:08 PM
GOD RAM IT's Avatar
GOD RAM IT
I explained it above.
do you know how the 4wd engauge system works on your truck?
Old May 18, 2006 | 03:34 PM
dodge_boy31807
Well it isn't for my truck but can you built one for a 2wd like my truck is. I want to make something to make the truck kick posi instead of buy a locker and without welding the spider gears. I'm actually a really good welder but I don't want to lose my truck in a slick curve. Can it be made for a 2wd to make it kick posi?
dodge_boy31807
