Tranny overdrive
Old May 20, 2006 | 01:12 AM
jb0578's Avatar
jb0578
Default Tranny overdrive
Recently purchased 98 1500 4WD with 170k. Transmission constantly shifts in and out of OD during speed of over 45 MPH, even on straight and level roads. Had the fluid changed and the bands are fine as per the transmission shop. The truck has been meticulously maintained and otherwise performs perfectly. Any suggestions and thanks.
Old May 20, 2006 | 01:16 AM
fiveliterbtr's Avatar
fiveliterbtr
Default RE: Tranny overdrive
Very common for the Throttle Position Sensor to cause this.
Old May 20, 2006 | 04:34 AM
Racinfan83's Avatar
Racinfan83
The TPS would be the first thing I would look into. Better yet - just go to your local parts store and get a new one for $32 and change it. Takes like 5 minutes to do it.......
Old May 20, 2006 | 04:03 PM
badram1500's Avatar
badram1500
definatly replace the tps. its on the drivers side of the throttle body, held on with 2 torx screws. simple to change.
Old May 20, 2006 | 10:20 PM
miknwv's Avatar
miknwv
I have kind of a similar problem, though no shifting. If I'm going 65 mph in OD my RPMs are right around 1900-2000. Sometimes my RPMS will slowly creep up to 2300 or 2400 without changing speed, power or gears...then it slides right back down to 1900. TPS?
Old May 20, 2006 | 10:29 PM
Chopper1's Avatar
Chopper1
Or torque converter.......
Old May 20, 2006 | 10:32 PM
miknwv's Avatar
miknwv
Ohh crap....please dont say that...LOL. It sometimes does it in drive too...RPMs will slip up a few hundred RPMs and then drop back down wtihout change in power and without shifting gears.
Old May 21, 2006 | 12:06 AM
jb0578's Avatar
jb0578
Thanks gents. After replacing the TPS, the tranny performs perfectly.
Old May 21, 2006 | 12:22 AM
miknwv's Avatar
miknwv
Sweet man, glad u got ur problem fixed. Transmission probs are scary, especially with a dodge ram. lol.... not to hijack the thread, but do yall think its TPS or TC on mine?
Old Apr 17, 2008 | 07:32 PM
shaneman18's Avatar
shaneman18
i have sort of the same problem. some times it takes a while for my OD to kick in. then today it worked fine but it was having trouble shifting from first to second. Would the tps do this to my trans or could it be the tcc solenoid i have herd that could cause the problems also.
