Truck dies and starts back up on its own? HELP!!!!!
Old Aug 16, 2006 | 01:40 PM
  #51
mandy750's Avatar
mandy750
Default RE: Truck dies and starts back up on its own? HELP!!!!!
no codes, but the computer on the top where the mpg is reads CCD. WHAT IS THAT?
Old Aug 16, 2006 | 01:44 PM
  #52
mandy750's Avatar
mandy750
WHAT DOES PCM MEAN?
Old Aug 16, 2006 | 01:50 PM
  #53
TMS Bill's Avatar
TMS Bill
PCM = Power Control Module ... your truck's brain. If it overheats and shuts down so does your truck. I have no experience with overhead console systems so the "CCD" means nothing to me. Someone else may recognize it though.
Old Aug 16, 2006 | 01:52 PM
  #54
mandy750's Avatar
mandy750
SO YOU MEAN IT COULD BE MY COMPUTER?
Old Aug 16, 2006 | 02:03 PM
  #55
TMS Bill's Avatar
TMS Bill
If you're not getting a CEL ... not throwing any codes ... but the truck shuts down when hot (no gauges, no indications at all) but it still cranks but won't start ... it sounds like the computer to me. If you had working gauges, I'd figure fuel pump cutting out.
It does still crank after it shuts down, yes?
Old Aug 16, 2006 | 02:09 PM
  #56
mandy750's Avatar
mandy750
IT WILL SHUT DOWN AND NOT TURN ON. YES IT STILL CRANKS OVER, BUT NOTHING. ONE OF THE MECHANICS PLACED A TEST LIGHT ON ONE OF THE INJECTOR PLUGS WHEN THE TRUCK WOULD NOT START, AND SAID THE THERE WAS NOT POWER TO THE INJECTORS. ALL THE LIGHTS ON THE DASH COME ON BUT NON OF THE GAGUES WORK. I PUT A NEW FUEL PUMP ABOUT A MONTH AGO.
Old Aug 16, 2006 | 02:18 PM
  #57
TMS Bill's Avatar
TMS Bill
The injectors are fired by the computer.
Don't panic ... if it is the PCM, they're pretty cheap. We've see rebuilt units for $66 on-line. I'm not tech certified but I am an electronics technician. I'd still wait and check with some of the more seasoned Dodge guys here before throwing parts at this problem.
You also might want to restart this problem in a new thread as you piggy-backed this onto the tail-end of someone else's problem. You might get more folks responding to it that way.
Old Aug 16, 2006 | 02:21 PM
  #58
mandy750's Avatar
mandy750
I ALSO THOUGHT I COULD BE THE CRANK SENSOR THATS WAY I GOT IN THIS THREAD. THANKS
Old Aug 16, 2006 | 02:22 PM
  #59
TMS Bill's Avatar
TMS Bill
Crank sensor won't cause dead gauges.
Old Aug 16, 2006 | 02:24 PM
  #60
mandy750's Avatar
mandy750
WHERE CAN I FIND THE PCM AT?
