Truck dies and starts back up on its own? HELP!!!!!
Old Aug 16, 2006 | 02:48 PM
  #61
TMS Bill's Avatar
TMS Bill
Default RE: Truck dies and starts back up on its own? HELP!!!!!
The cheapest one I can find right now is here: http://www.rockauto.com/catalog/x,ca...,parttype,2896
That's why I think you should ask some of the experts here before you start throwing money at your problem. This place used to have a number of rebuilds for $66 ... now they've only got one and it's $200 ... The "CCD" indication may be significant but I've never seen it.
Or do you mean where is the PCM on your truck?
Old Aug 16, 2006 | 03:15 PM
  #62
mandy750's Avatar
mandy750
tried rock auto and no page was found. WHERE IS THE PCM IN THE TRUCK?
Old Aug 16, 2006 | 03:42 PM
  #63
TMS Bill's Avatar
TMS Bill
Open the hood. Passenger side firewall. Silver box about 3/4" thick (size of a small magazine). 3 large connectors in a horizontal line. 3 screws hold it in place.
Don't know what the problem was with the link to RockAuto ... I clicked it and it went right to the page ...
Old Aug 27, 2006 | 01:03 AM
  #64
dxbaxelg's Avatar
dxbaxelg
I have a 93 that was doing the same thing when it was hot here in southern Utah. I replaced cam and crank sensors with no success. Fuel pressure & flow normal. By accident, I leaned my elbow on the PCM wiring where they connect to the PCM. I made the truck die. I found that as I wiggled the Crank Position wire at the PCM I could make the truck stall and "restart" as you describe. I am now in the process of replacing the pins located at the end of the wire bundle where the wire-loom plugs into the PCM. I talked to a dealer in Dallas who said that they had seen this problem quite often and have replaced many wire-loom plugs. The bad news is that Dodge discontinued the repair kit for the 93. (Problem must have been pretty common for Dodge to produce a repair kit?) Does any one have any idea where we can purchase a repair kit, especially the pins?
Old Aug 28, 2006 | 10:55 AM
  #65
sakdaddyg's Avatar
sakdaddyg
try ebay, or a junk yard.
if those are no help i am sure you can do a search for it online (google it) and you will surely find a place that has them.
