Truck dies and starts back up on its own? HELP!!!!!
Old Jul 20, 2006 | 02:03 PM
  #31
sakdaddyg's Avatar
sakdaddyg
Default RE: Truck dies and starts back up on its own? HELP!!!!!
ORIGINAL: wildwolf59
yeah but it does it sitting still at a low idle too......i changed the crank sensor last nite and knock on wood it hasnt done it yet but i didnt drive very long either....so i will drive it about 30 miles tommorrow and see what it does.....keeping my fingers crossed....lol
sweet!!! keep me informed, i am going to put the VSS sensor on today, i will let you know if it has an affect on the problem. It seems like a good place to start and i appreciate the research everyone has done on this problem. We can kill two birds this way, we will know if it is either of the two sensors causing this within the next two days.
thanks guys
Old Jul 20, 2006 | 09:42 PM
  #32
wildwolf59's Avatar
wildwolf59
FINALLY!!!!!!!FINALLY!!!!!!!FINALLY!!!!!!!! I HOPE TIS ISNT PREMATURE BUT IT HASNT DONE IT FOR TWO DAYS SINCE I CHANGED OUT THE CRANK SENSOR!!!!!!!! when i took out the old one it was a little worn and a little dirty and it hasnt acted up yet so i think i have solved the problem.....finally!!!!! i hope this helps you out sakdaddy and anyone else later on down the road.....because it drove me nuts about what it all could of been because it was so intermiddant.....so maybe you should try the crank sensor first sakdaddy!!!!!!! let me know what you did to fix yours!!!!!!thanx guys for all your time expertise and opinions.....i am very grateful!!!!!!![sm=smiley20.gif]
Old Jul 21, 2006 | 12:38 AM
  #33
TMS Bill's Avatar
TMS Bill
You seem so excited. I would be, too. How many miles do you have on your rig? I'd like to know when I might start seeing stuff like this.
Old Jul 21, 2006 | 01:23 AM
  #34
wildwolf59's Avatar
wildwolf59
mine has 70000
Old Jul 21, 2006 | 01:33 AM
  #35
TMS Bill's Avatar
TMS Bill
Hooboy ... I'm at just under 86k ... I think I remember putting a set of plugs in it once. Changed the oil 4 or 5 times (running straight synth 5w50 through two big filters). At least I know where to START looking if someting like this rears it's head.
Old Jul 21, 2006 | 12:18 PM
  #36
sakdaddyg's Avatar
sakdaddyg
awesome man! i hope you didnt jinx it...hahah. actually i had the sensor put on yesterday and the problem has not happened yet, but i am expecting it to anytime now, just becuase i am so used to it. We will see if it does. If yours does it again let me know and i will let you know if mine acts up as well.
I have 160,000 miles on my truck and it still runs like a champ, with an exception of this problem which hopefully i will have fixed. I have used my truck to pull trailers for most of the time that i have had it, so i have worked the thing but taken care of it as well,so anyone with a low mileage truck can expect to get quite a few years out of it which is definitely nice to know
Old Jul 21, 2006 | 07:49 PM
  #37
wildwolf59's Avatar
wildwolf59
yeah thats why i keep up to date on here so if the same problems acts up with someone else they can check out our threads and hopefully get right to it before they change EVERYTHING on their truck.....lol ...and sakdaddy, i will let you know if mine does it again but by now it should have done it and it hasnt yet so i hope WE fixed it.....thanx guys again!!!!!!!!
Old Jul 21, 2006 | 08:49 PM
  #38
sakdaddyg's Avatar
sakdaddyg
on the way home from work today my truck did it again, not bad but it still happened.....so it is not the VSS sensor....i will now move to the crank sensor if you dont have any problems out of yours wildwolf. If it has not done it to you over the weekend, than please post that on monday and i will put a new crank sensor on.
thanks
Old Jul 23, 2006 | 10:13 PM
  #39
wildwolf59's Avatar
wildwolf59
ok sakdaddy.....i have went five days now and not once has it died.....so if i was you i would try the crank sensor, it is on the passenger side in the back of the motor in between the block and tranny housing.....kinda hard to get to but i finally got it....lol....solet me know if you change it and if that was it or not!!!!!!
Old Jul 24, 2006 | 01:14 AM
  #40
steve05ram360's Avatar
steve05ram360
Also, if you want a cheep mod... slot the mounting holes and move the sensor towards the center of the truck, this will add timing across the rpm range and a boost in power... downside is you MAY have a slight loss in fuel economy.
glad to hear your truck is fixed...
