Dodge Ram Dash Question
Old 07-11-2006, 02:46 AM
luap56's Avatar
luap56
luap56 is offline
Default Dodge Ram Dash Question
Can anyone tell me, who has done it, how do I remove the dash bezel on my 98 fullsize Ram, to access the radio, cluster, etc? I've been told it "just pops off", but, I'm afraid of breaking something. Any hidden screws, etc.? Thanks, Paul, Pa.
Old 07-11-2006, 03:06 AM
fiveliterbtr's Avatar
fiveliterbtr
fiveliterbtr is offline
Default RE: Dodge Ram Dash Question
On my 01, it just pops off...I had to put it in low gear to clear the shifter, iirc, but that's it.
Old 07-11-2006, 03:19 AM
Hookem 74's Avatar
Hookem 74
Hookem 74 is offline
Yeah, best way is to grab it right behind the steering wheel and kind of "Pop" it towards you. This will get it started, then just follow the frame around the rest of it pulling out on it. Couple of screw hold the radio in.
Old 07-11-2006, 04:19 AM
Chopper1's Avatar
Chopper1
Chopper1 is offline
I take it 98 was the year they moved the ash tray and drink holder??????????
Old 07-11-2006, 12:01 PM
vsraptor's Avatar
vsraptor
vsraptor is offline
ive poped mine on and of so many time messing with the radio that ive busted mine up pretty good. and in 12 wrecking yards one to replace it was hard to find recently. So be careful.........
Old 07-11-2006, 12:19 PM
dodgedlr's Avatar
dodgedlr
dodgedlr is offline
I think there is 1 screw in the corner of the accessorry outlet on the right side.
Old 07-11-2006, 02:36 PM
crazy1snow's Avatar
crazy1snow
crazy1snow is offline
no screws. it literally just pops off. i lower the drink holder, tilt the steering wheel down, and pop the shift lever (on my automatic) out a bit. grab it by the part right above the drink holder and just pull the corner up. it will just pop. just little metal clips in plastic holes holding it on.
yup doing the whole own radio thing teaches ya a bit about the ole "just pops off"
Old 07-11-2006, 06:04 PM
Big_N_Bad's Avatar
Big_N_Bad
Big_N_Bad is offline
yea it just pops right off, Just got done putting mine back on. Had to lower steering wheel though.
BNB
Old 07-11-2006, 06:26 PM
joeyp1974's Avatar
joeyp1974
joeyp1974 is offline
i have a 99 and mine just pops off also... only thing i have to do is lower the steering wheel and put the truck in gear
Old 07-11-2006, 07:29 PM
ljpierce_ely's Avatar
ljpierce_ely
ljpierce_ely is offline
DC changed the Ram interiors in 1998. They differ from the 97 and earliers in more way than one. The only two things you have to do to remove it is remove the screw that is located right next to the accessory outlet. Then tilt your steering column down. Another thing that will ease removal is putting the transmission in LOW (presuming you have an A/T and not a stick shift) When I remove my bezel, I start at either the left or right sides and just slowly work your way in. It just pops out. Try not to bend it around too much in removing it. It is plastic after all!!
Quick Reply: Dodge Ram Dash Question
