1999 5.2L fuel pump fuse
Old Jul 13, 2006 | 11:42 PM
Blu99ram's Avatar
Blu99ram
Default 1999 5.2L fuel pump fuse
I have been searching for a while, is there a fuel pump fuse on a 1999 Ram with the 5.2 motor? It is not in the fuse box under the hood and any help would be appreciated. Thanks.
Old Jul 14, 2006 | 12:13 AM
TMS Bill's Avatar
TMS Bill
Default RE: 1999 5.2L fuel pump fuse
If it's anything like the `98s ... it's not a fuse ... it's a relay. Under the hood, drivers side, relay block.
Old Jul 19, 2006 | 04:33 PM
Blu99ram's Avatar
Blu99ram
Thanks man. I was hoping it wasn't my fuel pump, but it seems that it is.
Old Jul 20, 2006 | 02:46 AM
The Burning Rom's Avatar
The Burning Rom
There is both a fuse AND a relay. They should both be in the power center under the hood
Old Jul 21, 2006 | 03:41 PM
Blu99ram's Avatar
Blu99ram
Which fuse is it on my 99. Even the chiltons that I have doesnt help. I havent found any fuse that would possibly be it.
Old Jul 21, 2006 | 04:16 PM
dodgerules86's Avatar
dodgerules86
If the 1999 is like the 2001, check fuse 9 (10A, in the junction block) and fuse 3 (20A, in the PDC)
Also, you can substitute another relay and see if that works. Or, just take out the relay, and test terminal 30 [which will be marked on the bottom of the relay] this should be hot at ALL TIMES via fuse 3) . There should be voltage to terminal 86 with the key ON (via fuse 9). Also, with the key ON, there should be continuity between terminal 85 and a ground (provided via the PCM).
*Also, what are these joint connectors? Joint connector #2 connects, amoung other things, fuse 3 to the fuel pump relay.
Old Jul 21, 2006 | 04:40 PM
The Burning Rom
It's probably fuse 3 (20A). It's a 20A Maxi-fuse (the big style) on my truck.
Why are you looking for this fuse?
Old Jul 21, 2006 | 04:49 PM
dodgerules86
ORIGINAL: The Burning Rom
Huh?
Old Jul 21, 2006 | 06:58 PM
The Burning Rom
ORIGINAL: dodgerules86
Huh?
I'm curious as to why the original thread starter is looking for the fuse. I'm guessing he has a problem. It might not be the fuse that's the issue
Old Oct 30, 2014 | 01:51 PM
BC. Dakota's Avatar
BC. Dakota
Default Fuell pump problems
I just had my fuel pump replaced on my 94 Dodge Dakota, but the fuel light is on and the gauge doesn't work. I'm hoping it's just a fuse.
