160 or 180 Thermostat
Old Jul 21, 2006 | 03:55 PM
ddog737374's Avatar
ddog737374
Default 160 or 180 Thermostat
ok its time to change out myThermostat and i have a Hypertech Power programer and it says to run the 180 but will it hurt if i go to 160 witch one will be better?
Thanks Dan
Old Jul 21, 2006 | 04:01 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: 160 or 180 Thermostat
Stick with the 180...you'll HATE the 160 in the winter.
Old Jul 21, 2006 | 05:13 PM
Silver_Dodge's Avatar
Silver_Dodge
The 160 will also almost always cause you to stay in open-loop mode which will cause you to run rich, and will throw code (p1281 I recall). 180 is definetly what you want to us.
Old Jul 21, 2006 | 11:59 PM
bamory's Avatar
bamory
Agreed
Old Jul 22, 2006 | 01:06 AM
rammed hard's Avatar
rammed hard
Would changing the thermostat on a 99' v-10 from the stock factory thermostat to one of these 180 degree units benifit my truck.Is there a specific make that I should look into . Truck also has the JET chip , K&N fipk, and looking into the throtle bodies from Fastman. I realize the chip not only interferes with elbow room in the engine compartment but might not provide suffient enough gains to warrent there use , but I need to run the truck on some longer trips to test its claim as to improving m.p.g.. So any input as to this configuration would be appreciated
Old Jul 22, 2006 | 01:47 AM
The Burning Rom
A 180* t-stat is defintely beneficial on the V10, especially if you have a performance PCM like I do. It's not a cheap part though. If I remember right, it's around $50-$60 [&:]
Old Jul 22, 2006 | 12:30 PM
shott8283's Avatar
shott8283
a thermostat for 50 or 60 bux?
wow..
8 bux if you drive a 5.2 or 5.9 L from napa
Old Jul 22, 2006 | 02:57 PM
pipedreams's Avatar
pipedreams
It's a HD unit.........and can be kind of a PAIN to change out. But the 180 is the only way to go in a V10 IMO.
Old Jul 22, 2006 | 08:31 PM
rammed hard
With the v-10 what are the performance gains that come with installing this unit. Is there a specific manufacturer that I should look into for the part.
I' ve replaced thermostat on other vehicles befor, does the v-10 present obstacles that i should leave up to the pros.
Thanks.
Old Jul 22, 2006 | 09:17 PM
The Burning Rom
ORIGINAL: rammed hard
It's not that kind of mod...one that will add x amount of horsepower or torque. It's a supporting mod...one that will help out other mods. It keeps engine temps down and reduces the chance of pinging/knock. It might help the engine make a little more power, because of the cooler temps, but not much. It's a MUST have when towing with a performance PCM.
It's also not one of those mods were there are a lot of manufacturers. STANT is a good manufacturer, but I only see them listing a 190* unit. Not sure who makes 180s actually. Maybe pipedreams will post the manufacturer of the one he posted the picture of.
Here are the install instructions: http://dodgeram.org/tech/gas/V10/v10thermostat.htm
BTW, the stock ones list from $21 to $35 at most auto parts stores. I know the dealer list in the $50 range [&:]
