No speedo and ABS light ??
Old Jul 22, 2006 | 04:46 AM
willyc's Avatar
willyc
Default No speedo and ABS light ??
Well I recently changed the speed sensor in the tranny because it was giving a DTC now my speedometer is all over the plave and my ABS and Brake lights are one,. What gives?
thanks, will
Old Jul 22, 2006 | 10:19 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: No speedo and ABS light ??
What year is your truck?
Old Jul 23, 2006 | 09:07 PM
willyc's Avatar
willyc
1999 2wd 5.2
thanks, will
Old Jul 23, 2006 | 10:17 PM
The Burning Rom
The speed/abs sensor on your rear axle is bad. IIRC you can pick one up at NAPA.
Old Jul 23, 2006 | 11:52 PM
wildwolf59's Avatar
wildwolf59
yeah i think they are about 29 bucks for that sensor!!!!!!!
Old Jul 24, 2006 | 03:39 AM
willyc's Avatar
willyc
Thanks alot guys. This is really wierd just two weeks ago the speed sensor on the tranny went bad, and now this sensor. Were is this one located on the rear end? Do I have to disassemble?
Will I have to use a scan tool to turn the ABS light off?
thanks, will
Old Jul 24, 2006 | 04:20 AM
The Burning Rom
You don't have to disassemble. It's on the top of the housing...towards the front. You'll see it when you get under there.
The ABS light should turn off after you replace the sensor. If not, unhook the battery for an hour and the codes will reset.
Old Jul 24, 2006 | 12:28 PM
TMS Bill's Avatar
TMS Bill
The ABS light will just go out and the speedo (and cruise control) will start working. No need to reset anything.
Old Jul 27, 2006 | 04:58 AM
willyc's Avatar
willyc
The only place I can find that carries this sensor is the dealer. Is there any other place or will I just have to buy from them. Does anyone have a part number?
thanks, will
Old Jul 27, 2006 | 11:06 AM
ASH's Avatar
ASH
Yea, I ran into that too. NAPA and Advanced Auto only had the sensor that goes into the transmission. I had to go to the dealer for the sensor in the rear end. I'm thinking the price was around $45, about the same as Advanced Auto's price for the tranny sensor.
