Water Pump almost DOA...Info on change
Old Aug 9, 2006 | 04:04 AM
ChaoticBastard's Avatar
ChaoticBastard
Default Water Pump almost DOA...Info on change
Well its grinding away.So its parked until I get time off to fix it.Now i have done many water pumps.Just wondering if there is any tricks or anything I need to look out for when I do it.The one book I have says I have to remove everything to do this,Rad,AC Compressor,Pull the power steerig to the side,etc.Now when i look at it it looks like i just need to remove the shroud,Fan and pull the Power steering pump out of the way?Does this sound right?BTW its a 96,.5.2 4x4 Thanks!
Old Aug 9, 2006 | 04:32 AM
Scottr1110's Avatar
Scottr1110
Default RE: Water Pump almost DOA...Info on change
it not that hard you dont have to mess with the power steering goto take the clutch fan off and the shourd which is a few bolts pull the ac pump off and move it to like ontop of the engine and remove the big bracket under it then just pull the water pump i did it all at once i did timing chain front cover gasket timing chain tensioner main seal all that somebody will probally post the link to the page that shows the pics on what to do
Old Aug 9, 2006 | 01:28 PM
steve05ram360's Avatar
steve05ram360
this may help... have a look.
https://dodgeforum.com/m_224411/tm.htm
Old Aug 9, 2006 | 02:56 PM
bamory's Avatar
bamory
Hey while your in there, you may as well pull the timing chain cover and replace timing chain, your already almost to it, may as well go a little further, and make sure you replace that little bypass hose, do not reuse it.
Old Aug 9, 2006 | 03:18 PM
steve05ram360
and if you do the chain, dont forget the front seal on the timing chain cover... and loosen the oil pan bolts a little so it comes apart easier. swapping the chain should only add about another 1~2 hours max. (depending on how comfortable you are with a wrench)
Old Aug 10, 2006 | 01:14 AM
ChaoticBastard
I think I will do that.Any good Timing chain replacements?or is OEM fine?Thanks
Old Aug 10, 2006 | 02:40 AM
bamory's Avatar
bamory
Go with a quality double roller from summit, thats what I did, and a little hint when you put in the seal for timing chain cover Steve spoke of, pack it full of white lithium grease, pops right into place, no muss no fuss, no bending.................oh and treat that oil pan seal at the bottom of the cover like a newborn baby, make sure it is set in the groove when you reassemble and be careful not to break it when you seperate chain cover from motor
Old Aug 10, 2006 | 03:12 AM
steve05ram360
ORIGINAL: bamory
and a little hint when you put the from seal for timing chain cover Steve spoke of, pack it full of white lithium grease, pops right into place, no muss no fuss, no bending.................
dude you take the fun out of wrenching... lol
Old Aug 10, 2006 | 03:25 AM
bamory's Avatar
bamory
Steve.....I will PM you next time I have hints, maybe we should only give out a little at a time.........lol.......keep the threads rollin in.....j/k
Old Aug 10, 2006 | 10:31 AM
ChaoticBastard
Nice,I will be tackling it Sunday.That writeup is great too.I will take some pics just in case.
