Where did you mount your amp
Old 08-27-2006 | 06:25 PM
HuntinHanson's Avatar
HuntinHanson
Default Where did you mount your amp
Just wondering where you guys mounted your amp. I'm ordering an mtx thunderform so under the back seat isnt an option. I was thinking maybe behind the backrest of the backseat. Does anyone know how to take that off? Anybody else have a good spot to mount it?
Old 08-27-2006 | 06:57 PM
stnlycup's Avatar
stnlycup
Default RE: Where did you mount your amp
dont know how big that amp is....i mounted mine under the drivers seat....worked great
Old 08-27-2006 | 07:07 PM
BlueBeast2's Avatar
BlueBeast2
i was thinking under the back seat if i ever put one in. but if thats not an option for you stnlycup's idea is probably the only way to do it
Old 08-27-2006 | 09:45 PM
Ram1500Dodge's Avatar
Ram1500Dodge
depending on the size of the amp, i def. would not put it behind the seat unless its a cheap ole amp you dont care about. There is not going to be any air flow back there to keep the amp cool thus giving it a short life and potential fire hazard.
Steve-o
Old 08-27-2006 | 09:48 PM
BlueBeast2's Avatar
BlueBeast2
ORIGINAL: Ram1500Dodge
Steve-o
So would under the backseat be a bad idea?
Old 08-27-2006 | 10:02 PM
HuntinHanson
stnlycup what did you do with the wires? I'm afraid of someone catching them on their feet when crawling into the back seat.
Old 08-27-2006 | 10:15 PM
iamjonnyr's Avatar
iamjonnyr
just put it under the drivers seat
i have the MTX thunderform as well and i just drilled a hole in the carpet for the wires to come through and then run the wires under the carpet/doorsill
Old 08-27-2006 | 10:21 PM
Tani1500's Avatar
Tani1500
i have my amp and 2 ten inch subs under the back seat. i pulled up the carpet and ran all the wires under the carpet all wrapped up. my amp is mounted on a piece of 16 alumium so it reflects the heat. the amp runs really cool actually.
Old 08-27-2006 | 11:09 PM
HuntinHanson
tani what all is involved with pulling the carpet up? Can i get away with removing screws or do i have to start pulling off panels?
Old 08-27-2006 | 11:18 PM
Tani1500's Avatar
Tani1500
all i had to do was take out the drivers seat. you might not even have to do that. i just pulled up the carpet under the dash enough to get the wires under. then ran them over to by the door. theres that pannel that sits on the edge of the door. theres like 4 screws in it. remove it and there was like a channel i just ran all the wires in. then up behind the panel by the back speaker and then i cut a hole in the carpet were the amp was going to go and pulled the wires under the carpet and in. having the seat out deff. made it easier though.
