Plenum Fix
Old 09-11-2006 | 03:57 PM
Sehr916's Avatar
Sehr916
Default Plenum Fix
Hi, I just ordered the kit from Hughes to fix the plenum pan/gasket. Is there anything i should be expecting? I swapped out the timing set so Im pretty sure I am up to this job. Just wondering If anyone had any special tips. Any special tools i need? Thanks
Old 09-11-2006 | 04:16 PM
steve05ram360's Avatar
steve05ram360
Default RE: Plenum Fix
hey hey... how's the truck running these days? if you havent seen it yet, there is a DIY writup in the DIY forum. check it out, it should help alot. Also make sure you use a felpro gasket. they are much better than the stock dodge replacement one.
are you going to mod your intake?
Old 09-11-2006 | 04:38 PM
Ramdamit98's Avatar
Ramdamit98
I just did my plenum using the DIY thread and the Haynes manual. Fairly straight forward. I left my fan in place as I didn't have a strap wrench, but it didn't pose any problems. It means alot of bending over and kneeling on the bumper, plus I'm not sure I would have got my fat *** between the rad and motor anyway. lol The only specialty tool was the lbs/in torque wrench which I had to buy as I only had a larger lbs/ft. If you have one for inches then there's nothing too special you need.
I forgot about the fuel line removal tool for romoving the fuel line from the fuel rail
Old 09-11-2006 | 06:05 PM
Socha_62's Avatar
Socha_62
I didn't need to remove the fuel line, it depends on the specific engine. Also if you don't have a puller of some sort you could screw the crank pully up, so make sure to get a puller But it is pretty straight foward! GL
Old 09-11-2006 | 07:30 PM
steve05ram360
the tool is under $10 bux and will make your life easier... remove the fuel line.
Old 09-11-2006 | 09:30 PM
Sehr916's Avatar
Sehr916
Okay thanks.
Its running like crap these days. I know im going to need to work on the tranny very soon.
Is that tool just called a fuel line removal tool or something?
Old 09-11-2006 | 10:17 PM
steve05ram360
yeah exactly... Kragens, autozone or napa should have it. it'll be a kit of up to 4 sizes.
Old 09-14-2006 | 12:18 AM
Sehr916's Avatar
Sehr916
Hey steve where can i get the fel pro gasket? I just bought the two items from Hughes. Im not quite sure what that includes. Thanks
Old 09-14-2006 | 12:59 AM
steve05ram360
you'll need to call around, I think Autozone had it. i'd wait until the kit comes in and see which gasket it has. I recall one of them having the good gasket.
Old 09-14-2006 | 01:05 AM
Sehr916's Avatar
Sehr916
Okay thanks will do
Quick Reply: Plenum Fix
