Old Aug 4, 2015, 07:36 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
2gen Bolt/Nut Size MASTER LIST! YOUR INPUT NEEDED!!!!!!
Old Sep 13, 2006 | 04:15 PM
shott8283's Avatar
shott8283
Default RE: 2gen Bolt/Nut Size MASTER LIST! YOUR INPUT NEEDED!!!!!!
i thought i mentioned that in the first post.. but ill doublle check and make sure i did
ill keep sending it TTT for now untill the list builds up a bit then ill have Tani sticky it and then ill work on a nice layout in either pdf and/or spreadsheet
Old Sep 13, 2006 | 04:49 PM
Ramdamit98's Avatar
Ramdamit98
ORIGINAL: shott8283
Yes you did shott. My bad. I put my specs for the crankshaft position sensor(V8). I know it's not in the same location for the V10 as for bolt size???
Old Sep 13, 2006 | 05:53 PM
RM_Indy's Avatar
RM_Indy
Good idea, here are a few more to add (1500/5.9/46re)
Crank bolt 32mm or 1 1/4"
Crank pulley 1/2"
Trans hard line brackets to engine 9/16"
Brake line to frame 9/16"
M1/Beerbarrel 1/2"
Water pump 9/16"
AC compressor 1/2"
Rad bolts 10mm
Pwr steering to head 9/16"
Tensioner 9/16"
Alt/AC main bracket 9/16"
Water pump 9/16
Motor mounts to frame 18mm & 21mm
Motor mount to motor 1/2"
Motor to trans 9/16"
Crossbar from motor to trans 1/2" & 5/8"
Starter motor 5/8" deep
Flexplate shield (46re) 7/16"
Oil pan to motor 1/2"
Flexplate to TC 9/16"
Old Sep 13, 2006 | 06:01 PM
Tani1500's Avatar
Tani1500
sweet this is coming out awsome, im gunna sticky it in alittle, if we let it free float alot more people will see it.
Old Sep 13, 2006 | 06:14 PM
Ram_Sport's Avatar
Ram_Sport
Tail light - T20 Torx drive
Old Sep 13, 2006 | 06:53 PM
Ramsrush's Avatar
Ramsrush
Seatbelt bolts #50 torx bit (95 1500)
Old Sep 13, 2006 | 07:03 PM
The Burning Rom's Avatar
The Burning Rom
ORIGINAL: shott8283
You did, but I was just mentioning it again, since I see a lot of posts with no designations
Old Sep 13, 2006 | 08:33 PM
TMS Bill's Avatar
TMS Bill
ALL Xfer case drain/fill plugs (according to dodgeram.org): 10mm allen
Old Sep 13, 2006 | 11:32 PM
shott8283's Avatar
shott8283
fricken awesome guys!!!! impressive i must say RM!!!! lol TTT for more viewing.. Tani and i will talk when we need to sticky this
Old Sep 13, 2006 | 11:39 PM
shott8283's Avatar
shott8283
ORIGINAL: The Burning Rom
ORIGINAL: shott8283
sweeet.. yea ill have alot of work after we close it and finalize it!!!!
