Old Aug 4, 2015, 07:36 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
2gen Bolt/Nut Size MASTER LIST! YOUR INPUT NEEDED!!!!!!
Old Nov 4, 2006 | 10:54 PM
  #31
ryans590's Avatar
ryans590
Default RE: 2gen Bolt/Nut Size MASTER LIST! YOUR INPUT NEEDED!!!!!!
hey shot its been a long time since ive been around here...but im back!!!
this is a great idea i cant think of much else to add however i did think of one thing but dont know if it really fits on here since its not bolts but i could give you some bulb #s, fues, (o know thats in the owners book but it your like me youll have no idea where it is at this point in time anymore i also have some wire codes (to put in alarms, remote starters ect.) if u want then just let me know
Old Nov 9, 2006 | 06:47 PM
  #32
shott8283's Avatar
shott8283
hey buster!! bout friggen time you cam back round'
yea htats a good idea bout the bulb numbers etc etc.. ill add that too along with wiring info for starters alarms and radios... ill pull that stuff off my 12volt database.. when i get some damn time ill be hopefully either putting this info in a pdf or spread sheet of some sort...
glad to see your back!
Old Nov 23, 2006 | 01:49 PM
  #33
Busted Knuckle's Avatar
Busted Knuckle
Cummins Turbo bolts:
Turbo to manifold: studs, 10 mm, bolts 10 mmx1.5
turbo to exhaust: bolts 10 mm x 50 mm 1.5
Old Dec 3, 2006 | 12:19 AM
  #34
RamOwna's Avatar
RamOwna
in the first post it says a 1/2" is needed for the oil pan to engine, i just my oil a few hours ago and mine was 5/8"
Old Dec 14, 2006 | 08:30 AM
  #35
RM_Indy's Avatar
RM_Indy
RamOwna
LMAO, your right!
Oil drain plug is 5/8" and is not in the freakin list. I only mentioned the 1/2 bolts that hold the oil pan to the bottom of the block and forgot the plug, duh.
Old Dec 16, 2006 | 11:53 PM
  #36
RamOwna's Avatar
RamOwna
ORIGINAL: RM_Indy
RamOwna
LMAO, your right!
hehe, just keepin everybody on their toes lol
Old Dec 20, 2006 | 07:21 PM
  #37
spiral72's Avatar
spiral72
nut on the ground strap, under the dash next to the glove box. - 1/4"
Old Jan 11, 2007 | 09:01 AM
  #38
HankL's Avatar
HankL
On a 1995 Ram
the screws that hold the PCM computer to the firewall
are 5/16
AND...Special Warning...
the lower left screw can't be removed by a 'normal'
nut driver or socket...a u-joint or special 'stubby'
driver is needed!
Old Jan 11, 2007 | 09:05 AM
  #39
HankL's Avatar
HankL
The fan on a 5.9V8 Magnum is kind of funky looking. It has 5 blades, but 2 of
them are bunched together and the other 3 are spaced out normally. There is a
stiffening wire embedded in the blades. It takes less than 15 minutes to take
this fan off, but if the fan had been made in two parts that split - you would
not have to take the big nut off the fan clutch - and the fan could be removed in 5 minutes.
Instead of buying a 36 mm wrench {1.417 inches}, I cut two strips of metal
from a tin can. These strips turned out to be 0.010 inches thick. I taped
two such home-made 'shims' to the inside faces of my 1 7/16 wrench {1.4375}
which closed the opening up to (1.4375 - 0.020) = 1.4175 This worked fine to
loosen the clutch-to-waterpump nut. Make the shims 'fish hook' shaped and you
can tape them in place from the backside. Or you can make the shim in a U-shape and use some of that red double sided 3M 'Super Strong' automotive trim tape at the bottom of the U to hold it in the wrench.
Old Apr 19, 2007 | 07:17 PM
  #40
AAA4948's Avatar
AAA4948
AC Compressor – ½”
Accell 3 bar map – 5/16” allen
Alt/AC Main Bracket - 9/16"
Alternator – 7mm & 10mm
Arp head studs - 9/16” 12pt deep & ¾” 6pt deep
Axle Shaft Nut - 1-11/16"
Battery terminals - 10mm
Bed body mounts - 11/16”
Body Mounts Cab – 12mm
Brake Line to Frame - 9/16"
Bumper Bolts - 18mm C9.25
Cover - ½” Caliper Bolts - 3/8 Allen
Castle Nut on Stock Trac Bar - 24mm
Collectors & Ypipe – 9/16”
Control Arm Lower - 21mm & 18mm
Control Arm Upper - 18mm & 15 mm
Crank Bolt - 32mm or 1 ¼”
Crank Position – 9/16”
Crank Pulley – ½”
Crankshaft Position Sensor – ¼” Allen as well as ½”
Crossbar from Motor to Trans – ½” & 5/8"
D44 Axle Shaft Nut – 1-11/16 β€œ
D44 Cover - ½”
D44 Filler Nut - ¾”
Edelbrock Headers – ¼” allen & 5/16” 12pt & ½” open(studs)
Fan – ½”
Flexplate Shield - 7/16"
Flexplate to crank – 9/16”
Flexplate to TC – 9/16”
Frame Line to Rear Brake line - 3/8”line wrench
Front Lower Shock Mount - 21mm
Gear Box Fluid Lines - 18mm
Gear Box to Frame – 7/8”
Harland Sharp 1.6rr (adj) stud/guide plates – 11/16”
Harland Sharp 1.6rr adjusters - 9/16”
Heads – 5/8”
Hub Bearing Retaining Bolts - 14mm 12pt
Hub Nut - 1-11/16”
Hub to Knuckle (3 bolts) - 14mm 12pt
Hughes 55 or Fastman 52 mm tbs – 3/16” allen
IAC - Torx 25
IAT - 3/4” open
Idler Pulley – 9/16”
Lifter Hold Down Plate – ½”
Lower Ball Joint – 1-1/8”
Lug Nut - 19mm
M1/Beerbarrel – ½”
Main caps – ¾”
MAP - Torx 25
Motor mount to motor – ½”
Motor mounts to frame - 18mm & 21mm
Motor to trans - 9/16"
Oil Pan to Motor – ½”
Piston Rod Caps – 9/16”
Pitman Arm Nut – 1-5/16” or 1-3/8”
Power Steering to Head - 9/16"
Radiator Bolts - 10mm
Rear Brake Line into Brake Cylinder - 5/16” line wrench
Rear Brake Line out from Rear Block - 3/8” line wrench
Rear Shackle Bolts - 10mm on the end of the bolt or torx on the head 21mm on the nut
Rear Shocks - 21mm
Seatbelt bolts - #50 Torx bit (95 1500)
Shock Tower Bolts - 15mm
Single Piston Caliper Bolts - 3/8” Allen
Spark Plug - 5/8” Starter Motor - 5/8" deep
Steering Column to Gear Box Buckle – ½” Steering
Stop Knuckle Screw (Stop Bolts) - 9/16”
Tail light - T20
Tensioner - 9/16"
Tensioner Pulley – 5/8”
Thermostat – ½”
Throttle Body Bolts - ½”
Throttle Linkage Bracket – 5/16”
TPS – Torx 25
Trac Bar Nut – 1-½”
Trac Bar to Axle - 18mm
Trans Hard Line Brackets to Engine – 9/16”
Transfer Case ALL Drain/Fill plugs – 10mm Allen
U-joint cap bolts- 3/8”
Upper Ball Joint - 1”
Valve covers - 7/16” deep
Vehicle Speed Sensor on Tranny – 1” 6 point Deep Well)
Viscous Fan clutch – 1-3/8” (14” adjustable)
Water Heater Fitting – 3/4” open or deep
Water Pump - 9/16"
Water Pump Pulley – ½”
Water Temp sensor (1pin/Drivers Side) – ½”
Water Temp sensor (2pin/middle one) – 11/16”
