fitting dual 19" electric fans? no problem...
When I installed my electric fan I drilled a hole in one of the mounting tabs of the washer fluid bottle then used a screw from the shroud and the mounting hole for the shroud to mount the washer fluid bottle. It seems to work realy well and has held up for over 6 months now. The coolant resevoir has just been zip tied to the frame. I haven't decided how to mount it yet.
It looks like they dont fit to well to me. You are probably gonna end up breaking the one on the driver side with the way it is angled like that. If those fans move as much air as my flex a lite 290s then it will put a lot of stress on the it where it mounts and over time could cause it to break.
I'm getting ready to buy a pair of electric fans, either 14 or 16. My question is are you guys running one fan all the time without any heat issues? I've got an e-thermostat that i'm setting to turn one on at 170-180 but I'm not so sure if I should run both or can I get away with running just one?
