Rev and speed limiter?
Old Sep 27, 2006 | 11:11 PM
junkman306's Avatar
junkman306
Default RE: Rev and speed limiter?
I'll give the search function a whirl. Thanks for the info.
Old Sep 28, 2006 | 02:17 AM
RM_Indy's Avatar
RM_Indy
If you have stock valve train then 5200rpms is the max rpms. Your springs are not strong enough to close the valves in time before the pistons get there. Beyond those rpms you risk floating a valve into a piston.
Old Sep 28, 2006 | 02:23 AM
shott8283's Avatar
shott8283
ORIGINAL: The Burning Rom
Why would you want to push your motor farther than that though? The 318 isn't a high RPM motor. The tach changes color there for a reason
I don't have the Viper rockers in my truck. I'm not sure if they even work on the V10. The people that have done the swap have noticed a slight improvement though. If I remember, it's around a $40 or $50 swap.
If you want a mopar computer, find my Mopar PCM ebay thread and see if there's one that will work with your truck.
just had to ask.. why wouldnt viper rockers work in your V10? they both are 10 cylinders.. do they use different heads? i thought a viper rocker would feel right at home in your V10.. and a better match up then stickin them in an 8
Old Sep 28, 2006 | 02:38 AM
The Burning Rom's Avatar
The Burning Rom
They might actually work. I've just never heard of anyone trying them on a V10, while I've heard of several people using them on magnum V8s. Most of the people I know of that have done rocker swaps on V10s have used the 1.7 crower rockers.
If I wasn't going for a cam, I'd probably look into it. But knowing I'll be doing a cam, I probably won't even bother with rockers. Just new lifters. Unless I get in there and find some wear on my stockers [8D]
Old Sep 28, 2006 | 02:53 AM
shott8283's Avatar
shott8283
yea.. the vipers were 1.6 but rollers right? or were they 1.7 tappets? i cant remember.. but yea if your going cam then i wouldnt worry about it iether..unless you really wanted rollers to free up that vavletrain friction.. but thats getting down to the nitty gritty.
Old Sep 28, 2006 | 02:59 AM
The Burning Rom
Viper rockers are 1.7:1 stamped rockers. They'd be a steal at $70ish if they were rollers They're a good bump up though from the stock 1.6s though. The rockers I'm thinking of are from the mid 90s Vipers though. They might have switched to rollers at the end of the 90s, before going to the 8.3L V10.
Old Sep 28, 2006 | 03:11 AM
shott8283's Avatar
shott8283
thats true.. wouldnt hurt to ask at the local dealer parts counter.. could be a sick mod for you to do and ya never know.. you might like the rr's and put the cam on the back burner
Old Sep 28, 2006 | 03:16 AM
The Burning Rom
ORIGINAL: shott8283
No chance of that happening I've seen what this motor can do cammed [8D]
Old Sep 28, 2006 | 03:50 AM
shott8283's Avatar
shott8283
