Plenum question
Old Sep 30, 2006 | 02:12 AM
timwag2001's Avatar
timwag2001
Default RE: Plenum question
will hypertech clear up the death flash. Is there any other way to do it?
Old Sep 30, 2006 | 03:52 AM
Ramdamit98's Avatar
Ramdamit98
Hypertech will definitely help and there's always modding the crankshaft position sensor.
I found this while researching the DF ... I knew about the base timing mod but did not figure it as a "CURE" for the DF:
WANT TO CURE THE “DEATH FLASH?
Do you have a 2000 or newer truck that no PCM is offered for or the dealer pulled 4 degrees of timing out of, with the DRBIII to keep your truck from having detonation or pre-ignition problems, and now the truck is a pig? Sluggish and generally will not spin the tires from a stoplight, even with a 360?
Then advance your timing.
Your timing is set initially by the crankshaft sensor and the distributor has the camshaft sensor in it to determine when the injectors fire relative to the amount of valve opening. So moving the distributor does not affect base timing. But moving the crankshaft sensor relative to it's current position does. The trick is this, and takes about one hour. This will work on any Dodge truck 92- to present except for the 4.7L or the V-10.
Remove the crankshaft sensor on the aft/passenger side of the block. It is held down by (2) 1/2" bolts and pulls out of the tranny bell housing when loose. There is a rubber grommet in the bell housing also, remove it. Now look at the sensor's bracket, notice the 2 bolt holes. Slot each hole 3/8" both ways, still giving the bolts something to hold onto. Then insert the sensor back into the bell housing, making sure you pulled out the rubber grommet. Thread the 2 bolts back in loose, then slide the sensor as far as it can, towards the oil filter, away from the intake. This will advance, moving it towards the intake in the same direction of crank rotation and will retard the base timing; do not do this unless your teenager is driving the truck. It will usually be limited by the bell housing how far you can move it. If you are really brave, grind the bell housing and fab a new adjustable bracket. This will add 3-4 degrees of timing across the whole board of advance tables, and cure the Death Flash problem in your Magnum. That'll be $5 please...just kidding!
COURTESY OF KRC PERFORMANCE (GACK! )
Old Sep 30, 2006 | 04:29 AM
steve05ram360's Avatar
steve05ram360
before you jump to conclusions on the plenum... yank the TB and look down there with a mirror & flashlight. unless it is visibly pooling on the bottom, it should be fine. remember your pvc sucks in gunk and will line the inside of th intake.
the pcm sticker is a good sign you've recieved the death flash... Another problem that can contribute to slugish performance is crap on top of the fuel injector screens... if you yank the intake, take time to pull off the rails & clean/flush the fuel rail. make sure the injector screans look clean.
Old Sep 30, 2006 | 07:54 PM
timwag2001's Avatar
timwag2001
Has anyone done this? Im gonna try it any way but im curious how well it works
ORIGINAL: Ramdamit98
Old Sep 30, 2006 | 08:09 PM
MAGICDSSMAN's Avatar
MAGICDSSMAN
I've done it I think it made a bigger difference in power and gas mileage than my hypertec. If you have problems with your truck pinging though I wouldn't suggest it. For those that are gonna have there tranny out or there intake manifold off that is one of the easeist times to reach it.
Old Sep 30, 2006 | 08:18 PM
timwag2001's Avatar
timwag2001
thanks
Old Sep 30, 2006 | 09:09 PM
Ramdamit98's Avatar
Ramdamit98
I've also done it. I wouldn't say it brings the truck completely back to where it was before the flash but it was a noticable gain. We did it to a buddy's truck also and he had similar results. Before the flash he could light the tires up and after the flash couldn't do it even on wet pavement. After the mod he can break the tires free just not as well as before the flash, but he also has bigger tires now.
Here's a thread a couple of us were talking about it recently.
https://dodgeforum.com/m_559686/mpag.../tm.htm#561042
Old Oct 1, 2006 | 12:55 AM
timwag2001's Avatar
timwag2001
i dont know if i did it wrong but i feel absolutely no difference at all
Old Oct 1, 2006 | 12:59 AM
timwag2001's Avatar
timwag2001
i used a dremel and grinded the holes as much as i could without making the hole open ended. i only got the holes about an extra 1/4 inch as opposed to the 3/8 of an inch that the article said. the holes that i have now are about 1/2 wide
Old Oct 1, 2006 | 01:01 AM
Ramdamit98's Avatar
Ramdamit98
Did you end up putting the rubber grommet back in. I just sent you a PM. If you put the grommet back in then it won't allow the sensor to move enough to see any difference.
