crank sensor mod question
Old Oct 7, 2006 | 07:56 PM
chief0299's Avatar
chief0299
Default RE: crank sensor mod question
Thanks for the info. Maybe I have an off year or aftermarket sensor because like I said, on the outer edges of the bracket, the metal is only 1/4in wide from the existing hole to the edge in the left-right direction. I went ahead and elongated the holes, but I left just barely (maybe 2/32) a little metal around the edges. If I were to go the full 3/8, it would pretty much leave the bracket hanging there, with only the lip of it making contact and being held down by the bolts. Should I just go ahead and cut it completely? Ramdamit, I did pretty much exactly as it appears you did. I left just a slight amount of metal on that outer edge.
Old Oct 7, 2006 | 08:02 PM
turkeyhunter1962's Avatar
turkeyhunter1962
I believe most of us have faced the same situation as you. I elongated mine as far as I could and it still did not get an extra 3/8 inch. Left a small amount of metal on the edge myself just like you did.
Old Oct 7, 2006 | 08:15 PM
Ramdamit98's Avatar
Ramdamit98
I couldn't get 3/8's either, just not enough metal there. I was going to open the hole right up to try and get some more room but I started to get a little bit of pinging so I definitely didn't need to go any more. I may have to adjust it back some, but I'm going to up my octane and I just put in some autolite 3923 sparkplugs to try and keep it from pinging.
Old Oct 7, 2006 | 08:43 PM
junkman306's Avatar
junkman306
Has anyone noticed much of a performance gain from this?
Old Oct 7, 2006 | 09:18 PM
turkeyhunter1962
When I did it I was able to immediately notice a change in throttle response. As I have driven more miles with it it even feels like the engine is running smoother. Before doing the mod my engine always hesitated during partial throttle ( normal driving ). It felt like a real dog.
Old Oct 7, 2006 | 09:32 PM
chief0299's Avatar
chief0299
After I got it all together, the motor seemed to rev up more quickly. Didn't notice much difference except for I was able to break the tires loose more easily in a turn. Came to a dead stop and did a brake stand. Normally it wouldn't break loose very easily and I think I can contribute it to the heavy fiberglass camper. Tires started spinnng fairly quickly. I have noticed a little bit more torque. Will keep an eye on the economy side for the next week or so.
Old Oct 7, 2006 | 09:39 PM
junkman306's Avatar
junkman306
I may have to try it. By the way, where is the sensor?
Old Oct 7, 2006 | 11:36 PM
chief0299's Avatar
chief0299
On the passenger side bank, reach behind the head and down. Kind of follow the tranny dip stick tube down. If you have a small inspection mirror, you can stick it back there and look. There should be 1 wire coming off of it. The wire on mine was green. The instructions say to do it from underneath the truck. I don't know how that was done because I had exhaust pipes and transmission in the way. It was easier for me to lay over the passenger front fender and reach behind with my left hand. I was able to get a deep well 1/2in socket and 3in extension on the bolt then put the ratchet on and start turning. I've got fairly skinny arms and there was no way I could reach up or around anything to get to the sensor from underneath unless I dropped the Y pipe.
Old Oct 7, 2006 | 11:53 PM
Ramdamit98's Avatar
Ramdamit98
I was able to reach up from underneath on my truck. It's a tight squeeze but once you know were it is you can actually see it a little. I prefer to see what I'm doing rather than doing it blind and reaching around the head. My buddy's truck we had to go around the head and I found it took longer, but as on chief0299's truck we weren't able to get our arms up past the pipes.
Old Oct 8, 2006 | 12:01 AM
junkman306's Avatar
junkman306
So do you just grind the holes out?
