custom bumpers
Old Nov 2, 2006 | 01:48 AM
  #21
crazy1snow's Avatar
crazy1snow
Default RE: custom bumpers
you shouldn't have to "cut off" the bumper mounts they are bolted on. three bolts hold the middle on and one bolt holds the outside support for the bumper. it's really quite easy to remove (been there done that, had to replace it about a year ago)
Old Nov 2, 2006 | 01:51 AM
  #22
muddy_blue_dodge's Avatar
muddy_blue_dodge
i meant cut it off where it attaches to the bumper, not the end that attaches to the frame. maybe im misunderstanding how its constructed, ill look at it closer tomorrow. nvm that question i guess.
Old Nov 2, 2006 | 02:20 AM
  #23
GOD RAM IT's Avatar
GOD RAM IT
it will be much easier to make your own. I tried what your talking about and the stock brackets arent strong enough for a beefier bumper and it just creates more fab time
Old Nov 2, 2006 | 02:45 AM
  #24
crazy1snow's Avatar
crazy1snow
well it's just bolted to mounts too on both sides. using some square headed "carriage styel" bolts under the plastic front fascia.
god ram it is right those things are pretty flimsy on the outside. the ones on the inside would possibly be strong enough, but you'd be better off making something up.
Old Nov 2, 2006 | 12:16 PM
  #25
muddy_blue_dodge
ORIGINAL: GOD RAM IT
yea i wasnt sure if stock mounts could hold the weight of a steel bumper.... thanx.
Old Nov 2, 2006 | 12:48 PM
  #26
Socha_62's Avatar
Socha_62
I'd just make new brackets too, 1/4" plate will be plenty
Make sure the welds on the brackets are perfect and really penatrate good. I don't wanna say use as many as possible but I would personally use at least 4 grade 8 bolts on the brackets to the frame, especially if your actually gonna use it and get jerked out from it.
Old Nov 2, 2006 | 03:12 PM
  #27
muddy_blue_dodge
ORIGINAL: muddy_blue_dodge
ORIGINAL: Socha_62
haha- thats the intention!! thanx for the tip..... am i correct when i say grade 8 flexes a little bit more than grade 5, meaning less likely to shear off?
Old Nov 2, 2006 | 03:57 PM
  #28
crazy1snow's Avatar
crazy1snow
NO NO NO NO NO!!!!!
grade 8 does not "flex" more it's made out of a different type of steel. meaning it has different mechanical properties that make it a stronger bolt by the fact that it takes a lot more force for it to shear than a grade 5. i think it has more carbon in it but not sure on that. (mechanical properties of materials... it's a fun class in college to take if you're going to be a mechanical engineer... aka point finger at myself... me.)
when looking at bolts the biggest way to tell the difference, grade three has no markings on the top, grade 5 has 3 dash lines going from the center to the outside of the head of the bolt, grade 8 has 5 of those lines. stupid confusing marking system but it's what it is. they might also have a 5 or 8 label on the head.
Old Nov 2, 2006 | 06:20 PM
  #29
Socha_62's Avatar
Socha_62
Grade 8 are gold too cause they're
[sm=bling.gif]
Oh yeah, the less carbon the strong is most cases
Old Nov 2, 2006 | 07:52 PM
  #30
crazy1snow's Avatar
crazy1snow
actually it does have more carbon... it's stronger in tension and compression but weaker in torsion. if you know what those terms are you'll understand (pulling, pushing, and twisting). just had a discussion with some other ME seniors on the subject.
