K&N FIPK No More
Old Mar 7, 2007 | 04:58 PM
  #221
Silver_Dodge's Avatar
Silver_Dodge
Default RE: K&N FIPK No More
Sorry, can't answer either of your questions. I didn't measure the breather grommet hole size, and I just fabbed an s-bolt to use with my setup.
Old Mar 8, 2007 | 04:06 AM
  #222
zique's Avatar
zique
ORIGINAL: hilliad
Thanks Zique. So you can use a straight bolt with the offset center you ordered? Not sure about my fabrication skills in making a S bolt.
That is correct. it lines right up. The kit comes w/ an S bolt, so you'll need to go to the local hardware store and pick up a 1/4"-20 bolt/rod.
The stand alone breather, I couldn't tell you for sure either other than I know it is bigger than the 3/4 inch ones that are most common. I just used an APC style that has a hose clamp and clamped it on the plastic elbow of the current breather set-up.
  #223
Racinfan83's Avatar
Racinfan83
For the guy looking for the breather filter......
Go to: https://dodgeforum.com/m_386820/tm.htm Scroll down to post #16 - I have a pic and part# on it for you.
I intend to go with the round air cleaner also - just haven't gotten time to do it yet.....
Old Mar 8, 2007 | 10:24 AM
  #224
firedog's Avatar
firedog
I see that Summit has a chrome 14" with a 2" or 3" reuseable filter for like $30. Whats the biggest size that will work for the 5.2? Would this be better the the edlebrock proflo?
Old Mar 8, 2007 | 12:20 PM
  #225
Silver_Dodge
ORIGINAL: zique
ORIGINAL: hilliad
I did not reuse the little elbow, I inserted the breather directly into the valve cover. Of course, I also have different valve covers then most, but I will try to get a better picture of the breather installed to put in this thread since the question comes up so much.
Old Mar 8, 2007 | 02:51 PM
  #226
hilliad's Avatar
hilliad
Ok, I ordered mine yesterday from Summit for about $28. Arriving on Friday this week. Bought a 1/4"-20 threaded rod to make the offset bolt. Last night I took off the plastic breather on the valve cover to see what size breather to buy and the darn thing broke into pieces. Had to literally pry it out with a screwdriver hoping none of would end up inside the vavle cover. By the way it takes a 1 1/8".
So what is the exact size of the offset? 3/4" or 7/8"
Old Mar 8, 2007 | 07:26 PM
  #227
Ramdamit98's Avatar
Ramdamit98
ORIGINAL: hilliad
http://www.v8performance.com/tipsandtricks.htm#s-bolt
Old Mar 8, 2007 | 10:00 PM
  #228
trukr36's Avatar
trukr36
I installed this one http://store.summitracing.com/partde...p;autoview=sku
1" offset on the bolt IIRC
Old Mar 8, 2007 | 10:03 PM
  #229
Silver_Dodge
I didn't even measure the s-bolt, just bent it till it looked about right. First one was not quite right, so I made another, and it worked perfectly. It really isn't that tough, so don't sweat it.
Old Mar 9, 2007 | 01:49 PM
  #230
hilliad's Avatar
hilliad
Just made my bolt back in the maintenance shop here at work. No problem at all when you have a 1/4" pipe bender. AC arriving this afternoon and can't wait to put it on. Thanks for all the help. Also putting in a 180 T stat this weekend.
