1998 Ram Shifter Automatic Replacement
Old Nov 12, 2006 | 10:48 PM
ellasman's Avatar
ellasman
Default 1998 Ram Shifter Automatic Replacement
Hey guys... I need some help with replacing my shifter on my steering column on my 98 Ram 1500. Basically the end of mine where the overdrive button is broke... so I went to the dealer and they gave me a brand new shifter...
I took apart my steering column cover and there is this dowl/pin that i have to pop out to replace the shifter with... the question is how do i remove that dowl/pin ??? do i push it up, or down towards the floor??? Is there a special tool i need or will a punch and a hammer work?? My local dealer wouldn't tell me how to replace it... they wanted to "professionally install it"
Anyway, thanks in advance for the help if anyone knows.
Steve
Old Nov 21, 2006 | 05:27 PM
ellasman's Avatar
ellasman
Default RE: 1998 Ram Shifter Automatic Replacement
Does anyone know how to do this???
Old Nov 21, 2006 | 05:59 PM
crazy1snow's Avatar
crazy1snow
if it's just a pin then a hammer and a punch should work, just be carful to use a small enough punch to not get suck and large enough to get the pin out.
i haven't had to do this, but that would be what i would do.
just be careful when using the hammer and punch not to damage any of the other components on the shaft or knock it out of position bend it or what not.
seems like something you should be careful with...
call a local auto shop that does work on dodges they would know and would be more willing to tell you. i'm thinking something like a transmission shop.
Old Nov 21, 2006 | 06:10 PM
ellasman's Avatar
ellasman
Well which way do i hammer... hammer up towards the ceiling or hammer down towards the floor???? i think these dowl pins are directional.... ??? meaning the have linings on one side of the pin...
Old Nov 21, 2006 | 06:21 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Shouldn't matter. It's a rolled pin, I bet. Fairly common in automotive usage. Just tap on it and drive it out. It should get to the point where you can grab the pin with a pair of pliers. Don't go too far, or else you rick wedging the punch in the hole and you'll be cussing yourself trying to remove the punch.
Old Nov 22, 2006 | 12:56 AM
Socha_62's Avatar
Socha_62
Check the FSM, probably will have some directions on how to do it. Probably your best best, or its just a roll pin like VW said
Old Aug 22, 2015 | 12:25 PM
doubleddino's Avatar
doubleddino
I just did this today!
Take a "C" clamp and a socket, place the socket on the TOP to allow the pin to come out. Place C clamp on top of the socket, and on the bottom of the pin. Tighten the clamp, and the pressure will push the pin up. When it is flush, loosen the clamp, and remove socket and clamp. A couple of taps with a punch will pop it loose, and you can pull it out with your fingers! Hardest part is keeping the clamp and socket lined up on the assy.!
Hope this helps!
Old Sep 22, 2020 | 02:27 PM
Rammin99's Avatar
Rammin99
So did you use a punch while you were tightening the C clamp? I need to do this
Hope this helps!
Old Sep 22, 2020 | 02:57 PM
He has one post, five years ago, in a 14 year old thread..... Don't expect an answer.
