Sounds like water schloshing
Old Nov 13, 2006 | 09:09 PM
IndyRamMan's Avatar
IndyRamMan
Default Sounds like water schloshing
When im at an idle, and i give it a sliiiight bit of gas, say to 1k or 1200, it sounds like water schloshing through a pipe from the heater core area....whats up with this? is there air in my system makin it do that?
Old Nov 13, 2006 | 09:48 PM
nmason's Avatar
nmason
Default RE: Sounds like water schloshing
mine has done it for 3 years
Old Nov 13, 2006 | 10:57 PM
stovepipe's Avatar
stovepipe
i hear it to i would like to know a fix for it.
Old Nov 13, 2006 | 11:01 PM
nmason's Avatar
nmason
everyone always tells me to check the coolant. my coolant is fine, my heat is good, i dont see anything not working the way it should, jsut have that horrible noise. ive started making sure the music is going when i start it up, that way i dont notice the noise
Old Nov 13, 2006 | 11:06 PM
mopar98's Avatar
mopar98
I've heard it in mine too. Not quite sure why it does it either.[sm=confused06.gif]
Old Nov 13, 2006 | 11:43 PM
IndyRamMan's Avatar
IndyRamMan
lol, a good load of help you guys are...haha, just kiddin.
if its on a lot of our trucks, i think its worth investigating, or not if its never caused an issue.
Old Nov 14, 2006 | 12:21 AM
TMS Bill's Avatar
TMS Bill
Read this thread: https://dodgeforum.com/m_591255/tm.htm
Talks about how to get air out of the cooling system.
Old Nov 14, 2006 | 03:10 AM
habeba86's Avatar
habeba86
Yep, keep filling up that coolant!!!
Old Nov 14, 2006 | 09:12 AM
HankL's Avatar
HankL
It is worth parking the Ram on as steep an uphill grade as possible for a few days.
If you look at the top radiator hose
and at the way the heater core hoses come out to the front of the intake manifold and water pump,
you will see how easy it is for air to stay in the coolant passages.
Old Nov 14, 2006 | 01:44 PM
IndyRamMan's Avatar
IndyRamMan
so, it IS air in the system. i figgured that. on all my other cars theres been some magic air relief valve or cap you open to get the air out. this truck, you have to have the thermostat exposed to do so?
