Misfire Codes
Old Nov 14, 2006 | 02:12 AM
cgb864's Avatar
cgb864
Default Misfire Codes
Iv been through the Forum Search and read alot of great advise on Misfire codes and likely causes. Iv changed the wires to MSD 8.5mm along with a Sumitt Performance Cap/Rotor. I changed the plugs a few months back with Bosch Platimums and just put in a full tank of Super Unleaded.
The CE light just came back on and the codes are P0300 and P0304 (Multiple and #4 misfire).
Iv checked down in the Intake and see only brown staining, no standing oil.
One of the posts I read on misfiring and plugs suggested Champion Truck plugs instead of the Platimums. Is this the next best step based on what I have?
Criss
96 1500 5.2 ext cab 4x4
Old Nov 14, 2006 | 11:31 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: Misfire Codes
First, check the routing of your plug wires. There is a TSB out there that discusses the proper routing. Second, how many miles on your truck? A clogged catalytic converter can cause a misfire. I would recommend taking the truck to a muffler shop and having it pressure checked. Mine was misfiring on #4 (plus an immense lack of power). The new exhaust system worked wonders.
Old Nov 14, 2006 | 05:21 PM
cgb864's Avatar
cgb864
Thanks for the help.
When I got the code again this AM I pulled the codes and again, P0300 and P0304. I put the Timing Light on it and have fire to #4. I don't notice a change in performance when the light comes on either.
Here are my #2 and #4 plugs.
http://i19.photobucket.com/albums/b1...m/P1000893.jpg
Old Nov 14, 2006 | 05:37 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Plugs looks fine. Check the wiring routing first and then have the cat pressure checked. Read this for the wire routing. Be forewarned: It's a royal PITA http://autorepair.about.com/library/faqs/bl654h.htm
Old Nov 15, 2006 | 10:19 PM
cgb864's Avatar
cgb864
Thanks
While I had the two plgs out I decided to check the gaps. I found most were about .040-.045 so I pulled them all down to .035 and I also re-routed the Coil wire. (the new 8.5mm Sumitt wire set came with a real short coil wire, so I had to get a stock replacement from Autozone).
Now that I re-set the gaps and re-routed the coil wire (shouldn't have the induction problems with the new MSD wires) the CE codes haven't come back and it seems to be running a bit better.
What other issues would I have with a bad Cat?
Old Nov 15, 2006 | 11:35 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: cgb864
Thanks
From my experience, a bad cat will cause a poor to little in acceleration, a tremendous loss of power on mild grades, and misfires. The misfire will typically happen on the passenger bank, since it is closest to the cat (short path of pipe). I didn't think to tell you to check the gap of the plugs. It was smart of you to do that.
If all maintenance is performed on a vehicle, the cat is supposed to never fail. That means regular oil changes, filter changes, and monitoring the O2 sensors, plugs, etc. If a local muffler shop can check the cat for free (pressure check or temperature check) then I recommend it just as a precaution.
Wasn't wiring the distributor, according to the TSB, an absolute joy? [:'(]
Old Nov 16, 2006 | 02:35 AM
cgb864's Avatar
cgb864
especially just after changing the cap and rotor a few days ago, yeah PITA [:@]
Criss
Old Nov 16, 2006 | 02:40 AM
timwag2001's Avatar
timwag2001
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
thats the tsb for wire routing. ive read that if you have the wires crossed improperly it can cause misfires. I guess if you have the wires crossed wrong at all it can misfire.. not just for the tsb. do a search on the net. you'll find something on it
