CB antenna mounts or where is yours mounted?
Old Nov 14, 2006 | 02:30 AM
magnum318's Avatar
magnum318
Default CB antenna mounts or where is yours mounted?
I want some pics of what looks decent on theses trucks. I have a wilson 5000 mag mont on top of the cab but it looks bad to me.
Old Nov 14, 2006 | 02:42 AM
jakebrake's Avatar
jakebrake
Default RE: CB antenna mounts or where is yours mounted?
running dual 4' firesticks on the headache rack, antennas aren't on in the pic cause I had to park in a cover garage[:'(]
Old Nov 14, 2006 | 02:46 AM
Tani1500's Avatar
Tani1500
got mine mounted on the drivers side hood. looks good. you can kinda see it in this pic
[IMG]local://upfiles/15914/48C8E7B60BD34FEAB98BC29C3F09079D.jpg[/IMG]
Old Nov 14, 2006 | 03:25 AM
helmsa's Avatar
helmsa
You can see mine on the cardomain link in my signature...I have a CB and Scanner, so I have two 4' firestiks using a firestik stake mount...A cb which is mounted on the driver side and the scanner which is mounted on the passenger side. I like these...I am going to add a cab gaurd and tool box some day soon, so that is why I picked the mounts I did...
Old Nov 14, 2006 | 07:47 AM
Racinfan83's Avatar
Racinfan83
K-40 mounted on my toolbox. If you do this you have to run a ground wire from the mount to the frame to get a good ground. I like it - had it this way since day 1. K-40 is a good antenna, and it has a twist lock base so you can remove it quickly for car washes, garages, etc.....
[IMG]local://upfiles/19461/30F6BEDD3D6C4F7EA681BDAFDF7E8328.jpg[/IMG]
Old Nov 14, 2006 | 09:07 AM
HankL's Avatar
HankL
worth a look over:
http://dodgeram.org/ki4cy/ramradio/antenna.htm
http://dodgeram.org/ki4cy/ramradio/radio_mt.htm
Old Nov 14, 2006 | 10:17 AM
dhvaughan's Avatar
dhvaughan
i have a 2ft firestick mounted just off the left front corner of the bed, sort of in that little hollow spot between the bed and cab. homemade bracket bolted to the top edge of the bed. 3in spring. i can drive into the garage and clear the door. reception is not as good as a big whip on top, but good enough.
Old Nov 14, 2006 | 12:14 PM
Socha_62's Avatar
Socha_62
I have duel 4' Firestik wips mounted to my tool box in the bed. Gets the job done and makes it looks like I mean buisness Before that I have a K30 magnetic mount on the cab.
Old Nov 14, 2006 | 02:28 PM
jakebrake's Avatar
jakebrake
Thumbnail Image
Looks like you need to swap to stainless bolts
Old Nov 14, 2006 | 03:09 PM
Racinfan83's Avatar
Racinfan83
Got Me! I was waiting for someone to say something about that.....[8D] I know. Looks like crap. I didn't have any stainless ones when I put it on there 5 years ago - and I keep thinking that one of these days I'm going to fabricate a different bracket that is a little taller and change out the bolts then......I need 36 hours in a day [sm=sigh.gif]
Socha, how do you have your duals grounded since they are on the toolbox like mine?
