looking for high output alternator for 5.9
Old Nov 20, 2006 | 11:29 PM
iplayintraffic's Avatar
iplayintraffic
Default looking for high output alternator for 5.9
I'm looking for a high output alternator for a 97 1500 with a 5.9 liter. The stock one isn't toast yet but I just put a plow (and eventually a dump kit) on it and when it does go I want to have one on hand to replace it right away. The right way... if anyone has any suggestions on where to find one reasonably priced please let me know.
Old Nov 21, 2006 | 02:27 AM
DieselDemon's Avatar
DieselDemon
Default RE: looking for high output alternator for 5.9
Buy a bracket and install dual alts. The truck will thank you for it...lol.
Old Nov 21, 2006 | 06:50 AM
akyne's Avatar
akyne
Mean Green Starters & Alternators: http://www.mean-green.com/
or
Wrangler NW Power Products http://www.wranglernw.com/
Old Nov 21, 2006 | 07:01 AM
habeba86's Avatar
habeba86
www.excessiveamperage.com
Nathan jst quoted me
"Those alternators are a little costly to build. The highest I can build them to is a 225 amp. I can custom build you a 100% NEW 200 amp for $370 or a 225 amp for $420."
Great stuff...I know lots of ppl who run these and havent had any problems....Nat is a good guy!!
Old Nov 21, 2006 | 08:44 AM
HankL's Avatar
HankL
some info in case it is of use to someone:
The '98 Jeep Grand Cherokee 5.9V8's did come with a 150 amp
alternator from the factory. I'm guessing it had largely to do with the
electric fan that they also came with. I just picked one
up to see if it would work on my Dakota. The answer is, no for any vehicle
before 1998. Different
connectors than on my '95. I thought there had been a switch in terms of
connectors
at some point and it turns out that it was in '98 and up. The part number
for anyone that is curious is 56041394AA for this piece.
https://dodgeforum.com/upfiles/3988/...AAA715D02F.jpg
I had seen where others had the question about where to get a high output
alternator for their HEMI Rams. After a little digging and some help from Bill
Marine Chrysler in Springfield, Ohio, I found a 160 Amp unit that SHOULD bolt
up to our (3rd Gen Ram) trucks. The p/n is for a HEMI Durango, but it SHOULD interchange.
Now for the bad news.....the 136 Amp unit can be had online for $112.80 USD.
The 160 Amp unit is $293.60 USD!! The p/n for the 160 Amp unit is 56028697AA.
The website I got the prices from was
www.newdodgeparts.com
FWIW, the list on the 160 Amp unit was $375.00 USD
and the difference in wattage between the two
was 345.6 Watts (V*A=W, using 14.4 Volts) Hope this helps.
makeitmopar.com has it for $275.25.
Item Number MSRP Core Price Price
56028697AA $367.00 $0.00 $275.25
Alternator
ALTERNATOR, Durango, 160 Amp, 5.7L 2004 - 2006
Old Nov 21, 2006 | 08:53 AM
shott8283's Avatar
shott8283
DD,, Ive been wanted to run duals with a desiel 205HO alt but I can't find that braket your talking about. is there one pre made for duals? I was gonna build my own bracket,, but if i can buy one that i know will work.. with dual red tops..
HankL
to get it right.. your saying for the 98+ cherokee's 150amp alt would only work on 98+ rams?
and the reason why I want so much power is because my fans draw ALOT and with my stereo and other power hungry goodies, along with future plans for mods, like maybe a plow,, i wanna build the electrical system up pretty beefy now.. my 136 is doing ok.. but the more crap I add, the more its having ahard time keeping up.. I wanna kick the dim light bug out the window as soon as possible...
Old Nov 21, 2006 | 10:33 AM
HankL's Avatar
HankL
For the 1998 Jeep GC 5.9L V8 alternator t would be a true 'bolt on' on the years above 1998
but for prior years it would just mean changing the electrical connections.
I haven't seen the Hemi Durango alternator
but I would suspect that it might also be adaptable to the earlier engines.
Old Nov 21, 2006 | 03:32 PM
Mayfair's Avatar
Mayfair
ORIGINAL: habeba86
Looks like a pretty cool site. Sounds like the guy is pretty stand up.
GREAT find habeba !!
Old Nov 21, 2006 | 10:23 PM
shott8283's Avatar
shott8283
I might look into running that 150 from a cherokee,, i plan on putting the truck back onto just its OEM style circuitry.. and then everything that I have added or will add will be soley run off the aux. alt and 2nd battery... this might work out best for me since i am a firm beleiver that high drain's on alternators dont effect mileage or power... well not enough to worry about it..id rather run 2 smaller alts seperatly instead of spending the $$$$ on huge or rebuilt-rewound style.
Old Nov 21, 2006 | 11:39 PM
shott8283's Avatar
shott8283
http://www.davesdcelectric.com/pages/1/index.htm
DD just pm'd with this link and asked me to post it.. i guess this site is kiler.. havnt had a chance to check-er-out yet..
