Help Removing Muffler
Old Nov 26, 2006 | 01:48 PM
H Justin H's Avatar
H Justin H
Default Help Removing Muffler
I have dual 40 Series Flowmaster mufflers that are bolted on instead of welded. I just tryed taking them off and I got the bolts off. However, I can't get the muffler off of the piping. It's almost like rusted on there. Is there any tricks to getting off the muffler?
Thanks
Old Nov 26, 2006 | 02:01 PM
dillonjm's Avatar
dillonjm
Default RE: Help Removing Muffler
It's because the clamps indent the metal to hold them onto the pipe. I've had luck using a heat gun or propane torch to heat up the metal where the clamp was and it should pull off easier then.
Old Nov 26, 2006 | 03:20 PM
Racinfan83's Avatar
Racinfan83
Heat, a wood block, and a big hammer.....
Old Nov 26, 2006 | 07:41 PM
H Justin H's Avatar
H Justin H
What if I don't have a heat gun or torch? Would a shop do it for me for cheap?
Old Nov 26, 2006 | 08:16 PM
20dodgeram01's Avatar
20dodgeram01
cut it off
Old Nov 26, 2006 | 08:26 PM
H Justin H's Avatar
H Justin H
Don't have a sawzall either.
Old Nov 26, 2006 | 08:50 PM
20dodgeram01
i never had any luck just unbolting and pulling the exhaust off becuase of the crimped pipe.. if you have a hack saw that would work but will take a little longer
Old Nov 26, 2006 | 09:48 PM
H Justin H's Avatar
H Justin H
Alright, I'll try giving that a try.
Old Jul 16, 2008 | 03:36 AM
Sehr916's Avatar
Sehr916
Im having this same problem. I used a hack saw to to cut off the portion that attaches to the tailpipe (took several hours) but that left the output shaft still stuck on the tail pipe.
What should I do for the input?
I bought a FM 50 series SUV and it doesn't look like its going to fit with the stock piping. What should I do to make it fit (length wise)?
Thank you
Old Jul 16, 2008 | 12:50 PM
Cereal Killer's Avatar
Cereal Killer
Just cut the pipes as close as you can to the inlet and outlet. That's how I had to do mine. A sawzall would be ideal, but I just used a hacksaw. I'd keep a couple spare blades on hand. I went through 3 I think.
