Going to Napa specifics please
Old Dec 20, 2006 | 02:27 AM
steve05ram360's Avatar
steve05ram360
Default RE: Going to Napa specifics please
http://store.summitracing.com/egnsea...115+4294839113 these are for a 5.9... same wire set..
Old Dec 21, 2006 | 05:40 PM
mattyge's Avatar
mattyge
ok got everything except the wires, prolly going to order them but before i do one question, because they are thicker than the 7 mm stock ones does that mean i need a better coil. My coil went couple months ago and i replaced it with an OE replacement will this make a difference?
Old Dec 21, 2006 | 08:15 PM
steve05ram360
no, it'll work fine. if you do upgrade look into the MSD coil as well. Accel coils have had problems on the rams so i'd caution you against them... with the bigger wires you will need larger separators... I got a set of 8.0's and filed them some so the 8.5 wires would fit.
Old Dec 21, 2006 | 08:28 PM
mattyge's Avatar
mattyge
oh ok now i was looking through some online stores and i came across these and would like your opinion on them they are the ones from jegs. http://www.jegs.com/webapp/wcs/store...28681_-1_10691 also at my local store they sell bosch and champion wires are these any good either? I also noticed after i went to napa that the cap did not look like it had brass terminals they are of a silver colour is this ok. THanks again for your help
Old Dec 21, 2006 | 08:42 PM
steve05ram360
skip the brass cap & rotor, OEM is the best way to go... last time I did the Accell cap & rotor they did not last long. the wires would probably be fine, however I still recommend the MSD's... stay away from cheepies...
Old Dec 21, 2006 | 08:53 PM
mattyge's Avatar
mattyge
ok thanks very much for your help i'll have to make up my mind and i'll let ya know how it goes, hopefully with pictures
Old Dec 22, 2006 | 12:16 AM
Aubrey's Avatar
Aubrey
I absolutely agree about the wires. My mileage improved when I put mine on. I have an Accel coil and I didn't notice any difference (never had a problem either)so not worth the money anyway.
