Misfire help
i think it feels al little bit peppier. its hard to tell. i'm deathflashed so im having some performance issues. getting a msd setup and a fastman in about a month. all my mods should compliment the msd and fastman pretty well.
not very hard at all. you just drill out the little rings and bolt it back on with washers. you need a voltage meter... you stick it in the middle wire and play with the sensor untill you get the correct volatge (.75 volts if i remember right) and tighten it up. while i was tightning it, the sensor was moving just enough to throw the voltage off though. its a little tricky to tighten it and hold it in place. but all in all, it was pretty easy.
the only one that was kinda a pain in the *** was the cps... because its in an awkward place to reach
