01 ram doesnt start? any ideas?
Old Dec 31, 2006 | 10:59 PM
01silverram's Avatar
01silverram
Default 01 ram doesnt start? any ideas?
went out to go grab some grub and the truck didnt start. it turns over and turns over but nothing. i can smell gas but? The amp guage has always been right of center and now after attempting to start it its now on the left just where the line starts (so its in the neg).Light on battery is a dim green also.Ive never had a problem with the truck, except for the truck having NO *****.
any help would be great.
Old Dec 31, 2006 | 11:05 PM
Chopper1's Avatar
Chopper1
Default RE: 01 ram doesnt start? any ideas?
Is it turning over slow or at normal speed.
Did you let off the key and wait a second and try again.
Is it coughing, stuttering or attempting to start.
year model engine
Old Dec 31, 2006 | 11:08 PM
01silverram
normal speed
[IMG]local://upfiles/52218/5164B13A602E4BAFBE9CAD9DC52D21C7.jpg[/IMG]
Old Dec 31, 2006 | 11:13 PM
01silverram
it barely wants to start.....and i mean barely. It kinda chugs 3 times at the end. Its the 2000 Ram quad cab sport with the 5.2L automatic.. i tried a few times. i even waited 30 min and tried again.
Old Dec 31, 2006 | 11:22 PM
akyne's Avatar
akyne
If it's turning over at normal speed then your battery isn't the culprit. Your ammeter will always show a discharge when you have a load on the system but the truck isn't running. Start with the basics, good spark? fuel pressure? Also, there's not too many of us, at least those of us with V8's that complain about our truck having "no *****" and being that your truck is an SLT, I'm going to assume it's at least got the 5.2. If it's legitimately lacking power, that could be sign of a bigger problem related to your truck not starting, or something totally unrelated such as the infamous "death flash" or a plugged cat. For now, just start with the basics.
Old Dec 31, 2006 | 11:24 PM
Chopper1's Avatar
Chopper1
Try jumping it with jumper cables. If it starts then either battery or connections. will help solve the battery delima.
Fuel pump
crank sensor
Old Dec 31, 2006 | 11:27 PM
01silverram
yeah ive read about the cat being plugged and i have a 3" dual exhaust on the way plus i planned on leaving the cat off. what the heck is a death flash?
thanks for your help also.
Old Dec 31, 2006 | 11:29 PM
01silverram
ill try the jumper deal when my gf gets home with the other Ram.......... its runs great and is baged up, lol and mine looks great and doesnt run!........damn dodges!, lol
how easy/hard is it to replace the crank sensor or fuel pump?
Old Dec 31, 2006 | 11:42 PM
akyne's Avatar
akyne
The death flash was just something the geniuses at Daimler Chrysler thought of to mask the wicked pinging problems with the magnum motors as a result of the defective plenum gaskets that plagued these trucks all the way through production. Basically they figured if they tuned the computer way down, retarding the timing curve and everything, they would stop the pinging problem. It worked, somewhat, but the motors that had their PCM flashed with this "authorized software upgrade" barely had enough snot to get out of their own way! Search "death flash" on the forum and you'll find out all about it.
Old Jan 1, 2007 | 12:22 AM
01silverram
yep i have the sticker! authorized software upgrade. So how much is it to fix the problem then? or is it better to get a programmer?
thanks all
