Seatbelt Light Stays On
Old 03-01-2007, 10:03 PM
20dodgeram01's Avatar
20dodgeram01
20dodgeram01 is offline
Default RE: Seatbelt Light Stays On
yup if that plug is unplugged.. it'll stay on
Old 03-02-2007, 05:02 AM
whiteram00's Avatar
whiteram00
whiteram00 is offline
quick fix,if it comes back on again, get a strip of black tape an apply to light in dash or take the light out j/k i do know when its really cold out my dome light switch in the door freezes an when i open my door the lights dont come on till i wiggle it loose cold wether might have a factor in it
Old 03-02-2007, 05:35 AM
habeba86's Avatar
habeba86
habeba86 is offline
I never even noticed a seatbelt light in mine
Old 07-20-2008, 06:33 PM
lab4x4's Avatar
lab4x4
lab4x4 is offline
i just bought an 04 1500 crew cab 5.7 hemi and the seat belt light has been on since i bought it im planning to go out of town with it so i'm gona get it checked out , but i tried unpluging the wires under the seat and the light and alarm still stayed on and its p#%^ing me off
Old 07-20-2008, 11:46 PM
krs7272's Avatar
krs7272
krs7272 is offline
Mine is due to something in the buckle not always syncing. As it comes on goes off all day long if you push on it or wiggle the seatbelt it will go off. Before my warranty ran out when I had it in the dealer and didnt seenm to want to fix it because the seatbelt was in fine operational working order.
I'm about to just pull the bulb I know when my belts on.
Old 07-21-2008, 05:32 PM
johnnyrocket5363's Avatar
johnnyrocket5363
johnnyrocket5363 is offline
Mine is driving me crazy, too. I figured out how the switch works, and reworked it to start off circiut closed and pulling the belt opened the circuit, and starting off circuit open and pulling the belt closing the circuit.... I finally did the tape thing...
Old 02-16-2015, 07:05 PM
JRRamirez's Avatar
JRRamirez
JRRamirez is offline
Originally Posted by MagnumVP
99 Dodge Ram Quad Cab
For 3 days now the Seat Belt Light stays on all the time. I have checked the fuse and everything looks good. Have played with the seatbelt itself by just plugging it in and unplugging it. Done the same thing to the passenger side.. just in case.
What else could be the issue? Nothing else seems to be effected.
Not sure if this matters, but it has been 20 degrees recently at night and even freezes water left inside. This occured after the 3rd day of the freeze.[/align]
I own a 2005 dodge Dakota magnum with the same stupid problem one day it just started ringing even though I was buckled up all I did to fix it was follow the wiring from the buckle to the harness unplugged the harness and stuck a staple in it one end on each of the holes and taped it in place it acts as if you're buckled up all the time easy fix just rig it
Old 02-16-2015, 07:06 PM
JRRamirez's Avatar
JRRamirez
Default problem solved
Old 02-16-2015, 07:16 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,214 Likes on 2,965 Posts
Seven year old thread?
Old 02-17-2015, 02:26 PM
dean98ram1500's Avatar
dean98ram1500
dean98ram1500 is offline
I've got a similair dilemma, but I had switch the seats with seats from a 2001, but were the same seats, no power or heat or anything, and had different connections, ever since I swapped them the seatbelt light is on.
Quick Reply: Seatbelt Light Stays On
