tranny shot? no forward movment!!
great shape 97 1500 standard cab 4x4 318for 1100!!!! its a 46re and i bought it with a bad tranny, go fig! it has full power in reverse, but in drive it wont even move. is the tranny shot? need adjustment? clutches? solenoids? he said it didnt grenade it slowly just stoped going. pleas help thanks.
RE: tranny shot? no forward movment!!
From the FSM:
NO DRIVE RANGE
(REVERSE OK)
1. Fluid Level Low.
Add fluid and check for leaks if drive is restored.
2. Gearshift Linkage/Cable Loose/Misadjusted.
Repair or replace linkage components.
3. Rear Clutch Burnt.
Remove and disassemble transmission and rear clutch and seals. Repair/replace worn or damaged parts as needed.
4. Valve Body Malfunction.
Remove and disassemble valve body. Replace assembly if any valves or bores are damaged.
5. Transmission Overrunning Clutch Broken.
Remove and disassemble transmission. Replace overrunning clutch.
6. Input Shaft Seal Rings Worn/Damaged.
Remove and disassemble transmission. Replace seal rings and any other worn or damaged parts.
7. Front Planetary Failed Broken.
Remove and repair.
NO DRIVE RANGE
(REVERSE OK)
1. Fluid Level Low.
Remove and repair.
Trending Topics
I bought my 3/4 ton like that did the exact same thing. I got a rebuilt kit and a new TC for around $250 and did the job my self. The obvious problem with mine was my rear clutch was destroyed. All of the plates were severly warped and there was no material left on them. Plus the plate they all sit on was cracked in three places(not included in the rebuild kit like $20 from dodge). Did all this and the truck runs fine now.
