Regular Cab Sub Setups?
Old 02-09-2007, 10:05 PM
Dodgeboy328's Avatar
Dodgeboy328
Dodgeboy328 is offline
Default Regular Cab Sub Setups?
I recently came into possession of a Rockford Fosgate 10' P2. I paid fifty bucks for it box and all! I've already got a 450 watt amp. I'm going to put everything together weekend after next. I would really like to keep my storage racks so right now I'm thinking about cutting a third of the bottom rack off. I was just wondering how you guys with regular cabs set up your subs.
Old 02-10-2007, 01:38 AM
habeba86's Avatar
habeba86
habeba86 is offline
Default RE: Regular Cab Sub Setups?
I took my storage thing out........You could take out the middle seat.....There isnt alot of options. Like you said, you could cut some of the store bin out. It really jst depends on what you wanna do.
Old 02-10-2007, 12:07 PM
2001mustang_gt's Avatar
2001mustang_gt
2001mustang_gt is offline
i took my bins out and put a 12 behind each seat and put my amp under the middle seat
Old 02-10-2007, 12:16 PM
ramchrgr88's Avatar
ramchrgr88
ramchrgr88 is offline
I too took out my storage bins. I have 2 10 inch pioneers powered by 2x500 watt amp. the box is perfectly square and fits behind the seats just right so the subs aren't touching anything. I dont recal the cubic feet of the box, or the dimensions, but i built it myself, and it only cost me 10 bucks. I dont have pictures of it with the grey carpet on the box yet, and its too cold outside to get some new ones.
[IMG]local://upfiles/37884/3A5024103EBB49DFB3D4F1402A342AEA.jpg[/IMG]
Old 02-10-2007, 01:41 PM
Ram_Sport's Avatar
Ram_Sport
Ram_Sport is offline
i just took the bins out and did the best i could which is the best you can since im perfect lol, seriosuly tho u realy dont need the bins unless u have a lotta crap back thereand even then they still seem like not really worht it
Old 02-10-2007, 09:53 PM
94ram4x4 5.9's Avatar
94ram4x4 5.9
94ram4x4 5.9 is offline
I don't have any pics, but I took the storage bins out, and built a box that goes all the way from the diver side and leaves about 10" on the passenger side. I had to make a shelf-like cutout in the center with a channell running along the bottom to connect the 2 sides in order to clear the center console coming up and down. It's pretty sweet and sounds awesome with my port exit on the passenger side. I only have an old RF 12" with a 350watt amp, but it sounds awesome!
Old 02-10-2007, 10:03 PM
m_ross05's Avatar
m_ross05
m_ross05 is offline
i took out the shelves and made a box 33in long 14 high angled depth 8in at bottom 2in at top..and it barely fit with a 12in sub...had it all the way against the passenger wall and the middle seat would rub the carpet on the box slightly when raised up and down...i did a quickie and stuck the amp behind the drivers side...could see any of the wires or amp unless u pulled the seat up
Trending Topics
Old 02-11-2007, 05:01 PM
livinginh's Avatar
livinginh
livinginh is offline
Mine the same way, I took my bins out, put my box back there with the 2-RF 12" and put my amp under the middle seat, works really well, amd my seat almost goes all the way back if needed but not quiet. I have about 10 inchs of space on each end and if needed I can put smaller things on top the box for temp storage. With the 12"s and the 6x9's in the doors and the 6"s in the back corners that all I need in there anyway.
Old 02-11-2007, 05:10 PM
m_ross05's Avatar
m_ross05
m_ross05 is offline
yea i forgot to mention that the passenger side seatcould not be put all the back...within an inch though...since the speaker was touching the back of the seat i bet the seat would move in and out close to and inch and it vibrated so much...felt like a massage..i also noticed that the sub was a lot louder when the windows were down or cracked
Old 03-05-2007, 01:27 AM
cr80renob's Avatar
cr80renob
cr80renob is offline
I came across this very clever box that sounds like it would fit your needs perfectly! Hope this helps.....
http://www.supercrewsound.com/shop/detail/11/299.htm
Shane
Quick Reply: Regular Cab Sub Setups?
