PLEASEE HELP BAD BAD CLICKING SOUND
Old Feb 14, 2007 | 04:42 AM
carsrok's Avatar
carsrok
Default PLEASEE HELP BAD BAD CLICKING SOUND
like the title says i've never heard a car do this but ok i hae a 97 ram auto and now just under normal driving it clicks like all get out its either in the front or back right, and like its so loud it echos through neighboor hoods and i get the dirtiest looks going through parking lots
Old Feb 14, 2007 | 06:38 AM
radwebster's Avatar
radwebster
Default RE: PLEASEE HELP BAD BAD CLICKING SOUND
ya sure no one put zip ties on your driveshaft??
seriously though, you might need to be more descriptive. have someone walk or drive next to the vehicle so you can pin point where the noise is coming from.
Old Feb 14, 2007 | 03:29 PM
2001ramsport's Avatar
2001ramsport
U joints!!!!!!!!
Old Feb 14, 2007 | 03:33 PM
1969roadrunner's Avatar
1969roadrunner
Or - as was my case - a broken weld on the muffler which allowed it to come in contact with the drive shaft. Really nasty noise,resonated inthe cab even... If you still have a stock (or atleast chambered) muffler, check that. If it is rubbing you will be able to see the contact on the driveline too.
Old Feb 14, 2007 | 03:36 PM
1969roadrunner
Oh, and if it is contacting your driveline, be sure to keep your eyes on it in the future... It wore mine down pretty good.
Long story short - it snapped in two at 135mph at 3 am in the morning after graduation.
That was the first and last time I had my truck that fast... Now I'm limited to 120 becuase of the slipping overdrive clutches in my transmission...
Old Feb 14, 2007 | 04:01 PM
Cereal Killer's Avatar
Cereal Killer
ORIGINAL: 1969roadrunner
Well I'd say that about myth busts the one about the back end of your truck pole vaulting over the front end of the truck due to the drivetrain snapping at high speeds... good to know
Old Feb 14, 2007 | 04:39 PM
1969roadrunner
Nope, just makes a hella lotta noise while it's floppin' around under there... At worst you could cut some lines or wires, and maybe mess up your rear end if you got it stuck in a pot hole or something...
By the way, that was on Mythbusters' amd yes, it was busted...
Old Feb 14, 2007 | 04:45 PM
Cereal Killer
Really? I'll have to keep an eye out for that one. I feel alot better now that I know that
Old Feb 14, 2007 | 04:47 PM
ShakyJay's Avatar
ShakyJay
Wheel bearing, u-joint, brakes, broken weld, so many possibilities. Really hard to say could be any of those things. Ashas been said need to narrow the sound down a little more to exact location.
Old Feb 15, 2007 | 02:39 AM
carsrok's Avatar
carsrok
well my friend said that he could hear and feel it under the front right i think its just the front like diffrential almost
