guys help me with this
Old Feb 17, 2007 | 10:51 PM
Tani1500's Avatar
Tani1500
Default guys help me with this
ive asked this about 4 other places but no one seams to be any help. my girls 04 grand cherokee desided today that it wants to get its windows stuck in the down position. she said the fuse is fine so idk where to start.im guessing a relay or bad contacts or something. she was cleaning it today and so maybe she got something wet with cleaner. idk havent seen it yet but its 20 degrees outside and this blows. where how should i start looking. damn heep lol
Old Feb 17, 2007 | 11:28 PM
TPSDODGE's Avatar
TPSDODGE
Default RE: guys help me with this
its gonna be the regulator there like 285 bux its a cable type the cables brake all the time
Old Feb 17, 2007 | 11:38 PM
982500Ram's Avatar
982500Ram
I have had this problem a few times...sometimes its the switch or the motor.... I usually start looking at the switchfirst because its the easiest.I try and hook 12V's up to the motor ifthe motor moves then it's somewhere else and at least you can get the window up for the time being. If the cable is broken as TPS saidI think you will probably hear the motor working.
Old Feb 18, 2007 | 02:16 AM
Tani1500's Avatar
Tani1500
i havent seen it so idk whats up but i want to get a general idea. is there even a relay for it? idk i guess ill see what happens
Old Feb 18, 2007 | 02:28 AM
TPSDODGE's Avatar
TPSDODGE
the motor and regulator are one assembly and can not be bought alone. if it frezes a lot where you are from she prob try to use window when it was froze and caused the cable to break and the window came down thats what happens most of the time. I probally sell 2-3 of those regulators a week...
Old Feb 18, 2007 | 04:35 AM
zique's Avatar
zique
I had a similar thing happen in my old grand am. It ended up being the the two brackets that actually hold the window to the cable were cheap plastic that broke. I could still hear the motor working, so if she can't, this isn't the same thing. However, a lot of the GM and Chrysler vehicles used this same set-up in order to save costs. I actually ended up just pulling the assembly and gluing it all back together with some pretty heavy duty stuff. Worked like a charm.
Old Feb 18, 2007 | 10:13 PM
Tani1500's Avatar
Tani1500
from what i know its an electical problem as none of the windows work. she should be getting home tonight so ill see.
Old Feb 21, 2007 | 04:05 AM
radwebster's Avatar
radwebster
did you figure this out?
she probably checked the fuses under the dash or whereever they are in the jeep. but there's ususally another fuse/relay box under the hoof that handles either a fuse or a relay for all the power windows. i would definitely check that.
Old Feb 21, 2007 | 04:16 AM
hometheaterman's Avatar
hometheaterman
I had a problem with only the drivers window on my Honda and it was the switch but it could be a motor or something else. Hard to say without seeing it.
Old Feb 21, 2007 | 11:34 AM
topsites's Avatar
topsites
I think you're looking at a relay issue, get a manual and locate the one that's responsible for this, likely it's in that box under the hood, usually along the driver's side but get the Haynes manual.
