1996 Ram wiper fuse problem.
Old Feb 20, 2007 | 03:22 PM
wisconsinmagnum's Avatar
wisconsinmagnum
Default 1996 Ram wiper fuse problem.
Hey I have a 96 Dodge Ram single cab short box. its my not so daily driver. the other week i drove it to work and back used the wipers everything worked. then 2 days later get in to go to work...... and nothing. get to work check the fuse. it was bad. so I went got a fuse (same fuse) 20A
I had the key in and turned to on. put the new fuse in. "POP" ?????
tryed it with the key out. no pop. turn the key. "POP"!
so with the warmer weather i was looking around made sure nothing was in the way of the arms. tryed another fuse....... well you know why I am here. LOL
I just want to know where to start looking. I am thinking its a wire problem if the fuse pops even before i turn on the wipers.
any help is welcome.
Thanks
Matt
Old Feb 20, 2007 | 03:26 PM
red98ram's Avatar
red98ram
Default RE: 1996 Ram wiper fuse problem.
i turned my wipers on also a couple days ago and they started working shut them off turned back on and POP so idk lol i tihnk im having the same problem
Old Feb 20, 2007 | 03:28 PM
wisconsinmagnum
thats kinda funny. in a not so good kinda way.
I hope we find someone that fixed it.
Old Feb 20, 2007 | 04:24 PM
red98ram's Avatar
red98ram
yea sure we will, this is a great forum and there is tons of info on here and alot of guys/gals with alot of knowhow
Old Feb 20, 2007 | 07:51 PM
DieselDemon's Avatar
DieselDemon
Fuses only blow 1 of 2 ways. An overload, and direct short.
Go under the hood and disconnect any wire harnesses attached to the wiper motor. Now replace the fuse and see if it blows. If it does, there's probably a wire with a cut, or chaffed insulation. (naturally the key and wiper switch have to be on).
If the fuse doesn't blow, leave everything on (key, and wiper switch), then plug the harness(es) back in and see if you get a big spark, that ultimately leads to a blown fuse. If the fuse blows, then your wiper motor windings, or it internal contacts may have broken off to create a dead short. Sometimes a brush, or piece of magnet can jam things up.
You can even disconnect the linkage at the motor to make sure it's not the wiper arms themselves that are binding up.
Hope this helps.
Good luck with your ride.
Old Feb 20, 2007 | 09:06 PM
red98ram's Avatar
red98ram
um my wipers turn on when they key is out of the ignition? what would cause this? i did not buy the truck new but i do know there are foglights wired in to a swich and then there is a trailer brake system wired in...
Old Feb 21, 2007 | 09:57 PM
wisconsinmagnum
working on this problem tonight
Old Feb 21, 2007 | 10:16 PM
wisconsinmagnum
i dont know what to unplug
Old Feb 21, 2007 | 10:22 PM
wisconsinmagnum
ok unpluged right from the motor. and no pop of the fuse. plug in the motor. and POP
so i guess this means i have a bad motor.
Old Feb 21, 2007 | 10:25 PM
DieselDemon
Motor could be the problem. Could be some bad contacts as well.
I would think it's purchased as a complete unit.
