cb radio
Old Feb 21, 2007 | 04:07 AM
padodgeram's Avatar
padodgeram
Default RE: cb radio
DX 88HL
[blockquote]
[ul][*]Frequency Counter (with "ON/OFF" switch)[*]Small Meter with Scales for Signal Strength and Power Output[*]Red/Green Transmit LED[*]Roger Beep (with "ON/OFF" switch)[*]Noise Blanker/ Automatic Noise Limiter[*]+10 KHz Switch[*]SSB in addition to AM/FM/PA
[ul][*]PA Features:
[ul][*]Echo Board with Dual Control[*]Talk Back "ON" during Echo [/ul][/ul][*]Two Power Output Levels[*]10 Watts Maximum Power Output - AM[*]25 Watts Maximum Power Output - SSB[*]1.5 KHz Clarifier for Receive Only[*]5.0 KHz Clarifier for Receive and Transmit[/ul][/blockquote]
Old Feb 21, 2007 | 04:09 AM
echseman's Avatar
echseman
right on.
Old Feb 21, 2007 | 04:15 AM
padodgeram's Avatar
padodgeram
ranger makes good cb to... the galaxy and ranger are 10 meters radios... take em to a good cb shop (wink , wink) sometimes you can broadcast over radio stations thats power... gaxaly also has a
150Watts Maximum Power Output - SSB ...
Old Feb 21, 2007 | 08:07 AM
DODGEARCHER's Avatar
DODGEARCHER
ECHSEMAN: Hi I,m new here and this is my first post. I have a cobra 29 classic, with 2 firestick 4' ant. I have the ant's mounted to the bulk head of my bed. This setup works good for me.
Old Feb 21, 2007 | 12:07 PM
94ram4x4 5.9's Avatar
94ram4x4 5.9
I've been running a Cobra 29NWST for over 5 years and it is great! I had a CB shop peak and tune it and put a talk back in it so I could hear myself talk..I've used a K40 for a couple years then bought a 4' Firestick. Don't waste your time putting Two antennas on because you aren't really gaining anything because they arent far enough apart (from experience and many other people's as well) I have a PA hooked up to myne and a VHF radio for my fire and police mounted underneath it just above the 4wd shifter..It all really depends on what you want...you could spend $60 or so at walmart and get a cobra that you don't have to tune and comes with a WX band selector
Old Feb 21, 2007 | 03:04 PM
echseman's Avatar
echseman
i was thinking about going cheap, but i have done that before with other products, and it didn't turn out so well. when i go offroad, i have a heavy foot. so i needed something that was pretty rough, and could hold up to all the shock and bumping around.
Old Feb 21, 2007 | 03:08 PM
echseman's Avatar
echseman
thanks for your input guys, i will be looking at those radios and antennas at the local cb dealers. i definitely appreciate the opinions of experienced offroaders. thanks again!
Old Feb 21, 2007 | 06:58 PM
Socha_62's Avatar
Socha_62
I have a Cobra with dual 4' fiberglass antennas. I get alot of engine static through my antennas but thats because I ahven't grounded them yet.
Old Feb 21, 2007 | 10:37 PM
dhvaughan's Avatar
dhvaughan
i have a stock cobra 29 nw wx and a 2ft firestick w/3in spring mounted just off front of bed drivers side. it works good for 1-2 miles. a buddy bought a small cobra at wal-mart for for about $35 and runs a 3ft firestick. it works very good, maybe better than mine. a $5-10 noise filter in the power wire will eliminate the engine static. i have one.
Old Feb 22, 2007 | 02:17 AM
DieselDemon's Avatar
DieselDemon
RF Limited S-45 Omegaforce (Magnum Radio) and a Wilson 5000 magnetic. Great radio, works well for me.
It don't mean a thing if it ain't got that swing.........LOL.
[IMG]local://upfiles/12792/0C0A111190EF493E91385E3238AF6797.jpg[/IMG]
