posi-lok installed
Old Dec 28, 2012 | 11:22 PM
  #31
Wombat Ranger's Avatar
Wombat Ranger
All it does is let the axle disconnect engage manually instead of by vacuum. Doesn't affect the differential at all.
Old Dec 29, 2012 | 07:01 PM
  #32
dhvaughan's Avatar
dhvaughan
Originally Posted by cjd43
So if you install the posi lock do you still have the regular open diff? Or will it be fully locked diff when engaged?
welcome to df.
as said, it does not change the nature of the dif. it just replaces the trouble prone vacuum CAD with a solid, never fail manual lever. the design of the axle uses a 2 piece passenger side axle as an alternative to locking hubs. so the purpose of the CAD (central axle disconnect) is to engage the 2 piece axle (the equivalent of locking the hubs). if the vac cad fails, you have no 4wd.
http://dodgeram.org/tech/repair/4X4/4x4_engagment.htm
Old Dec 30, 2012 | 10:32 PM
  #33
h3lzsn1p3r's Avatar
h3lzsn1p3r
i have been looking at getting this my only worry is that i will loose the abillity to shift on the fly because the roads are hit and miss around here with the snow
Old Dec 30, 2012 | 10:33 PM
  #34
Wombat Ranger
^^ You have no reason to worry. That will not happen.
Old Jan 12, 2013 | 10:18 PM
  #35
wv ram's Avatar
wv ram
would it be possible to attach the cable to the gear shifter i have a 01 ram with the 5 spd tranny , any body did a posi lok with that , espiscally with the long cable
Old Jan 12, 2013 | 10:39 PM
  #36
Wombat Ranger
My friend clamped his to the shift lever of his NV4500 in his '98 Cummins. He likes it.
Old Jan 29, 2013 | 09:59 PM
  #37
95warlok's Avatar
95warlok
Default posi-lok
Just put one on my 2000 sport. Seems nothing fit right, lol. The nipple for my vent tube wouldn't thread in. The tube that holds the sensor went in like half a turn. Now it shows 4wd on all the time. I'm wondering if I'm going to have to crank that tube down tight. It's metal so should cut its own threads, as long as I don't have to take it back out again.
Yeah it's a bit different than the regular cad for activation. I have to stop, put it in 4h pull the lever roll forward a bit as I pull and pulls out about another half inch....tighten it down and go. Taking it out is pretty much the opposite.
