posi-lok installed
Old Feb 22, 2011 | 08:01 PM
  #21
dhvaughan's Avatar
dhvaughan
can you not see the 8 pictures embedded in the first post?
if not, try here: http://s519.photobucket.com/albums/u...ughan/posilok/
also see here:
main tech index. http://www.pavementsucks.com/tech.php
posilok. http://www.pavementsucks.com/tech-article-29.html
Old Feb 23, 2011 | 07:18 AM
  #22
Rave71's Avatar
Rave71
also see here:
No I could not, they aren't loading for some reason but thank you for those links!
Old Feb 28, 2012 | 01:28 PM
  #23
srma63's Avatar
srma63
I'm new to this forum, although I've been a MOPAR truck fan for many years. I used to have a '66 W200 and it was great fun working on it. It went to a new owner many years ago, but now I have a '94 RAM 2500 4x4 with 5.9L mill and 5-speed manual shift. There's an outfit selling through eBay that has two kits, both Alloy USA. One is the PSL400 being discussed here; the other is a Differential Cable Lock P/N 450400. The components look very similar, but the PSL400 has a few extra items. I called the seller "oconeeoff-road" and the he told me that they were pretty much the same thing. OK, but they don't have the same description. Can anyone here give me a bit more information? The Buy It Now prices seem to be pretty good, $122.45 for the 450400 and $126.39 for the PSL400, both with free shipping.
Old Feb 28, 2012 | 02:15 PM
  #24
They both look like exactly the same thing to me.
Old Feb 28, 2012 | 04:11 PM
  #25
W8 a minute's Avatar
W8 a minute
I'm a big fan of this mod but I wish the cable came up through the floor and mounted to the transfer case lever. This was you could reach down with one hand and pull/push the cable and move the lever at the same time.
Old Feb 28, 2012 | 09:20 PM
  #26
mcweaver's Avatar
mcweaver
W8 - I don't see why you couldn't do it that way? Granted you would have to deal with alot of extra cable, but you could maybe cut it or find somewhere to wrap it all up and put some ties around it?
Old Mar 1, 2012 | 05:10 PM
  #27
srma63's Avatar
srma63
Question
OK, then what are the extra parts for (see images in attached file)? The first iamge is the one I can't seem to find any additional or comparative information on. Is it possible that this is an older kit and Alloy USA just changed the name for marketing reasons?
File Type: pdf
Old Mar 1, 2012 | 07:32 PM
  #28
I am going to bet that they both come with pretty much the same parts, just displayed differently.
Cable (obviously )
Housing.
Gasket
Fitting for vent tube.
4x4 electrical switch. Evidently different than the stock one?
cable bracket, and hardware.
E-clips for shift fork. (re-use your fork)
Some nuts/bolts that I can't see very well.
And of course, zip-ties to hold the cable out of harms way.
On the top pic, the only parts 'missing' that you see in the bottom pic, are electrical connectors, that in the top pic, are already on the switch.
Both kits are indeed complete, with everything you need.
Old Dec 28, 2012 | 06:16 PM
  #29
cjd43's Avatar
cjd43
New Member
So if you install the posi lock do you still have the regular open diff? Or will it be fully locked diff when engaged?
Old Dec 28, 2012 | 06:36 PM
  #30
Arde's Avatar
Arde
It'll still be whatever you have. This is just a shifter.
