O2 sensor replacement
Old Mar 2, 2007 | 08:27 PM
Mike454's Avatar
Mike454
Default O2 sensor replacement
i have 122,000 miles and i'd bet my left nut that the o2 sensors have'nt been chnaged. i have a '98 1500 4x4 with the 360, is anywhere from 200 to 250 miles to a 26 gal tank good? are these worth the $300 to replace all 4 of them, guy at the auto shp told me they would, just want to know your guys' imput is. thanks a lot! and i bought my back up lights, $30 kit at cabelas, installing them tomorrow
Old Mar 2, 2007 | 09:49 PM
trukr36's Avatar
trukr36
Default RE: O2 sensor replacement
I'd pull them out and clean them first before spending $300 to change them. I'm a big believer in cleaning before replacing if the sensors are costly, you got nothin' to lose. You have four? You have dual cats? My '98, 5.2 has two sensors on single exhaust..
"is anywhere from 200 to 250 miles to a 26 gal tank good?"
Well, it is a 360. My 318 runs the same mileage on 3/4 tank, roughly 14 mpg.
Old Mar 2, 2007 | 10:23 PM
mikecjn's Avatar
mikecjn
Not to steal the thread but what have you used to clean them with? I have a CEL and it is one of the O2 sensors. Was hoping I could clean it but didn't know what to use. I was going to try carb cleaner but didn't know if it was too harsh.
Old Mar 2, 2007 | 10:47 PM
dmdenike's Avatar
dmdenike
nothing abaisive on the sensors...and try not to damage it it harsh chemicals...then you WILL need to replace them...just be carfull
Old Mar 2, 2007 | 11:43 PM
mikecjn's Avatar
mikecjn
what can you use then??
Old Mar 3, 2007 | 02:18 AM
Mike454's Avatar
Mike454
what should i use to clean them with?
Old Mar 3, 2007 | 03:58 AM
JarheadX's Avatar
JarheadX
you clean them with CRC Electronic parts cleaner
Old Mar 4, 2007 | 02:33 AM
SactoRam's Avatar
SactoRam
How much difference would cleaning the O2 Sensors make on MPG? I get about the same 200-250 on 26 Gal. Got 175,000 on the motor.
Old Mar 4, 2007 | 03:06 AM
SactoRam's Avatar
SactoRam
Oh yeah how many O2 sensors are there? and where are they located? I'm borrowing this truck for a month or two and I want to get some better gas mileage out of this beast. It is rather fun to drive though.
Old Mar 4, 2007 | 03:39 AM
livinginh's Avatar
livinginh
Both my 97 and 2000 only have two of them, one right before the cat and the other is just past the cat or on the back side of it before the exhuast pipe starts. Easy to change yourself, kind of hard to get to the wiring plugs as one of them goes over the top of the tranny. I changed both of mine cost me a bit less then $140 for both.
