Engine Noises for 1998 5.9L
Old Mar 8, 2007 | 09:26 PM
farva's Avatar
farva
Default Engine Noises for 1998 5.9L
I have a 98 Ram 4X41500 with a 5.9L and a 4 speed auto transmission. Whenever I am at idle or in drive I hear a tap noise as if it were the valves tapping, yet it was serviced about two weeks ago and the engine was overhauled as per Chrysler Maitenence schedule. I can also hear the noise when I am cruising as well. There is 93300 miles on the odometer. I really need to know if its the norm or if I got myself a problem.thanks guys.
-farva
Old Mar 9, 2007 | 01:18 AM
jakemary's Avatar
jakemary
Default RE: Engine Noises for 1998 5.9L
might be a sticky lifter. my 98 2500 360 4x4 has the same noise.
Old Mar 9, 2007 | 01:33 AM
05SilverHemi's Avatar
05SilverHemi
What exactly did you have done as part of an engine overhaul? A tapping sound can be anything from a lifter to an exhaust manifold leak. Where exactly do you hear it coming from?
Old Mar 9, 2007 | 03:33 AM
farva's Avatar
farva
the noise is coming from the top end and as far as overhaul i had what was specified in the 99,000 mile item list as well ascleaning and polishing the pistons and the heads, alsoreplaced the wires and plugs and had the tranny inspected and flushed. Thats about it I can get more specific if you would like?
Old Mar 9, 2007 | 03:34 AM
farva's Avatar
farva
Is there any fix to a sticky lifter?
Old Mar 9, 2007 | 11:02 AM
Slade901's Avatar
Slade901
What is your oil pressure at when you hear this tapping noise?
Could be your oil pump pickup screen is partially clogged. Was the oil pan cleaned out as well of any gunk and debris?
Old Mar 9, 2007 | 11:37 AM
farva's Avatar
farva
The oil pressure is slightly below 40 at idle. The oil sump and pump were inspected and cleaned.
Old Mar 9, 2007 | 11:41 AM
Dodge4x4810's Avatar
Dodge4x4810
First, you could trying adding some Marvel Mystery Oil to the oil. I had engine noise and during an oil change i added a can of Marvel and it makes the engine run a lot quieter, a lot of the noises went away. I add a can at every oil change.
Old Mar 9, 2007 | 12:29 PM
farva's Avatar
farva
thanks I will try that and see if it takess care of the problem.
Old Mar 10, 2007 | 06:55 PM
farva's Avatar
farva
Ok added some Marvel Mystery Oil and still have the noise what should I do? Should I tear the top end off and inspect or should I just leave it as is?
