B&G Flashed PCM Installed
Old 03-29-2007, 03:27 AM
ripto's Avatar
ripto
ripto is offline
Default RE: B&G Flashed PCM Installed
ORIGINAL: Silver_Dodge
I can't recall if the stock PCM locks the TC either in 1-3. Anyone know off hand?
A bit late, but just to answer your question, my TC locks up after shifting into 3rd (99% sure about this).
  #32
Old 03-29-2007, 11:30 AM
Silver_Dodge's Avatar
Silver_Dodge
Silver_Dodge is offline
ORIGINAL: kikidbird
Hey Silver, when you received your pcm, did it come with a spec sheet?
No I didn't request one, and I think some of what they do is proprietary so other companies can duplicate, which means they won't give you a spec sheet. I think if you were building a hardcore race enigne, and needed to know every single value they change, they would probably work with you on that.
ORIGINAL: ripto
Ya, mine still locks up in third, just at a higher speed/rpm.
  #33
Old 03-29-2007, 01:41 PM
lv360ram's Avatar
lv360ram
lv360ram is offline
ORIGINAL: HankL
If memory isn't playing tricks on me
I think one model year Dodge did change the programming
and locked the TCC more often...but then got a lot of customer complaints that the shifts were 'too often and too harsh'. This might have been model year 1998.
Soon afterI bought my 2001 Ram, I got frustrated with the TC locking in 3rd gear. It was an underpowered gas hog and the converter locking up in 3rd added to the frustration. Due to customer complaints, Dodge issued aTSB that removed that situation by having the dealer update the program. I got a nice surprise when I installed the Superchips program because it included removing the TC lockup in 3rd. Wow, the truck is so much more enjoyable to drive!
  #34
Old 03-29-2007, 01:47 PM
lv360ram's Avatar
lv360ram
lv360ram is offline
ORIGINAL: ripto
The stock PCM only locks the TC in 3rd and overdrive.
With the TC locking in 3rd I had to push on the gas harder to get the truck to accelerate. Without the TC lockup in 3rd the truck accelerates easier and I push on the gas less so I haven't noticed any reduction in gas milage.
  #35
Old 03-29-2007, 04:32 PM
ripto's Avatar
ripto
ripto is offline
Can you explain how the TC lock up hurts acceleration? Is it just because it decrease RPMs a little bit and therefore puts you further away from the power band? If thats the case I also have noticed it, I wasn't sure if the truck was just playing tricks on me or not but I have noticed that when it shifts into 3rd, and I know the TC lock up is coming, the truck does seem to slow down.
  #36
Old 03-29-2007, 04:50 PM
lv360ram's Avatar
lv360ram
lv360ram is offline
ORIGINAL: ripto
Can you explain how the TC lock up hurts acceleration? Is it just because it decrease RPMs a little bit and therefore puts you further away from the power band? Yes. If thats the case I also have noticed it, I wasn't sure if the truck was just playing tricks on me or not but I have noticed that when it shifts into 3rd, and I know the TC lock up is coming, the truck does seem to slow down. Yes it does.
You explained it just as I experienced it. I can't answer any better than you did.[sm=smiley20.gif]
  #37
Old 03-29-2007, 05:31 PM
Silver_Dodge
If our trucks made more low end power, you would actually want the TC to be locked up sooner. When your locked you are 1:1 ratio with your transmission, so all your power is going through the trans and to the wheels.
  #38
Old 03-29-2007, 05:49 PM
ripto's Avatar
ripto
ripto is offline
Silver, is it easy to remove the PCM from the firewall? Turns out I've got a jet plug in mine that I want to remove to see if it will affect my pinging. Ash I believe it was sent me the website from jet explaining how to do it but just curious. It doesn't affect any computer information right? Like the odometer, etc.
  #39
Old 03-29-2007, 05:51 PM
lv360ram's Avatar
lv360ram
lv360ram is offline
ORIGINAL: ripto
I see that you have Hypertech PPIII in your signature. Does the TC lockup occur in 3rd gear with the performance program installed?
  #40
Old 03-29-2007, 05:59 PM
lv360ram's Avatar
lv360ram
lv360ram is offline
ORIGINAL: ripto
If you have a Jet chip plugged into your PCM, be VERY, VERY careful when you remove it so you don't break off the securing tabs on the PCM. [sm=boohoo.gif]
Quick Reply: B&G Flashed PCM Installed
